lil more install help
Old Mar 5, 2003 | 10:52 PM
Ludecrew's Avatar
Ludecrew
Default lil more install help
allright ive got a MRD-M500 amp waiting for my other 4chan to come in
do i have to connect both the remote wires to my HU so both wires go 2 the 1 off the stock harness
also is it safe in the mean time to run my rear MB Quart speakers off of the m500 amp
thx
Old Mar 6, 2003 | 12:01 PM
BigZ's Avatar
BigZ
Default Reply
First, no you could just jump one from the other.. but the wire from the HU is a constant on once the ignition switch is turned on.. stupid design.. atleast that's how the Bose system works.
I noticed on person on here put a device in from Soundgate that gets a signal from a spkeaker lead and provides a remote voltage to the amp.. it's the TRIGSPKR model. Here is a link that has it for pretty cheap
http://www.circuitdeal.com/automotiv...ription-1.html $27.67
Old Mar 6, 2003 | 02:49 PM
jewellz's Avatar
jewellz
when i use 2 or more amps i normally put a relay in on the remote plus you can use it turn other things on as well ,like dvd ,nav or anything else you want to come on with the stereo.
Old Mar 6, 2003 | 06:15 PM
Ludecrew's Avatar
Ludecrew
do I just connect a wire going from the remote on the amp to the blue/white wire on the wire harness
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
