pricing help
Old Sep 19, 2006 | 06:00 PM
jonathan0702's Avatar
jonathan0702
Default pricing help
if im not able to install myself because of time restraints... how much do you guys think it would cost to install new speakers(infinity kappas) just in the front of my gsedan running them from an amp(JL, already installed) in the trunkwith stock HU
thanks all!
jonathan
Old Sep 20, 2006 | 06:34 AM
StreetOC192's Avatar
StreetOC192
Depending on the area rates, most shops will install door speakers for around $40-$50 if the wire is already run into the doors. If they need to run the wire into the doors, it might cost an extra $20 or so. Don't forget the extra cost if they need to supply any spacer rings or speaker wire.
Ken.
Old Sep 20, 2006 | 05:38 PM
jonathan0702
Thanks Ken, that really does help a lot! I had a pretty large estiment and knew i could come to you guys for help!
Jonathan
Old Sep 22, 2006 | 06:48 AM
Nazar's Avatar
Nazar
Unless you are running big power speakers do not need to run speaker wires in the door. And make sure you find a qualified shop. Price is not everythin. If they screw something up in most cases it will cost you more in agrivation then money.
BTW the doors are easy to take apart. I have had plenty of customers install their own door pods without any professional help. It is actualy more time consuming to get speakers in the dors with spacer rings then it is with our door pods.
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
