Amp to Sub conection - is this right?
Old Sep 27, 2006 | 12:20 PM
first350's Avatar
first350
Default Amp to Sub conection - is this right?
To connect my Amp to sub, should I connect the sub voice coils (2 @2ohms each) in series to obtain 4 ohms for the amp? (I'm thinking that if I cononect it in parrellel to get 1 ohm I would have too much current going through it)
Amp:
Kicker 5-Channel Amplifier (06ZX7005) 06ZX7005
-70 watts RMS X 4 ch
-“subwoofer channel that delivers 210 watts of Class-D power to one 4-ohm sub—or 420 watts to two 4-ohm subs (2-ohm total load).”
Sub:
Kicker 10" Subwoofer (CVR10) 05CVR102
Peak power: 600 Watts
RMS power: 300 Watts
Frequency response: 25 – 500 Hz
Impedance: Dual 2 Ohms
Sensitivity: 85.5 dB
Cabinet: Ported - 1.25; Sealed - 0.8
Sealed box: 0.8 - 3.0 ft^3
thanks for the help!
-Peter
*I tried searching for a few hours and couldn't find a similar set-up with enough details.
Old Sep 27, 2006 | 01:37 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You got the wrong subwoofer or amplifier.
The subwoofer's coils are 2-ohm.
The amplifier wants a pair of 4-ohm outputs.
You can't get there from here.
You needed a dual 4-ohm woofer to gather as much power from the amplifier as possible without blowing it up. The best you can do is half the amplifier power - 210 watts across your pair of 2-ohm coils in series.
Old Sep 28, 2006 | 06:28 AM
first350's Avatar
first350
thanks paul - I just realized the difference between the 2 identical 10" kicker subs that were online...either 2 or 4 ohms - good thing I didn't open the box yet.
thanks again!
-peter
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
