How to Remove 2006 Door Panel
Old Oct 8, 2006 | 05:45 PM
pesci's Avatar
pesci
Default How to Remove 2006 Door Panel
Not sure if anyone has already posted, but after searching a few times, I only found for 2003 - 2005.. So for those of you that do not know, this is how..
First remove the window switch panel. I found using a small screw drier and prying on a corner, poped it off..
Next remove the two 10 millimeter screws that are located under the switch panel.
Then remove the plastic cover located behind the Door handle. 10 millimeter
Now pull the door panel from the bottom away from the door. Panel clips are all that hold the panel on to the door.
You will have to unclip three or four clips from the back of the door panel once you have it free from the door..
I found when installing my new speakers it helped to lower the window all the way down to make sure that the tip of the window did not hit the speaker.
The passangers door is the same only you have to remove the pull handle first then the switch panel and then the screws..
If anyone has any questions feel free to PM me..
Old Oct 9, 2006 | 06:48 AM
skyydiver's Avatar
skyydiver
great write up! thank you for doing this!
Joe
Old Oct 9, 2006 | 12:04 PM
pesci's Avatar
pesci
Glad it helped
Old Oct 9, 2006 | 02:38 PM
Interlagos Fire's Avatar
Interlagos Fire
I will be doing my amplifiers+sub install this week by my self and eventhough I watched my installer installing my MB Quarts from a month ago, this still helps me to have a hard copy print out when I'm going to run the speaker wires to the amplifiers, hence I would still need to remove the door panels. Great post!
Old Oct 12, 2006 | 11:13 AM
pesci's Avatar
pesci
Bump for the weekend
Old Oct 14, 2006 | 11:23 AM
sorphin's Avatar
sorphin
excellent.. i have an 06 roadster.. and the service manual (for an 06), is clear as mud, still giving the same procedure as an 05 and less..
Old Oct 15, 2006 | 11:49 AM
deviljon's Avatar
deviljon
dude thanks for the write up! i was in the middle of doing this but all i had was the 03-05 tutorial as well.
Old Oct 15, 2006 | 12:44 PM
deviljon's Avatar
deviljon
okay crap i broke 2 of those little pop in clips... where can i get new ones?
Old Oct 15, 2006 | 01:06 PM
pesci's Avatar
pesci
If you mean the Blue or white ones, I would go to the dealer asnd order some.. They are just door snaps..
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
