CD-Changer(s) Mounting Locations?????
Old Mar 11, 2003 | 11:51 AM
KJ-350's Avatar
KJ-350
Default CD-Changer(s) Mounting Locations?????
Where are you guys that are adding aftermarket CD-changers mounting them? If you've added an aftermarket CD-changer and have pics of where you mounted / installed them can you post them? I'm trying to get some ideas for where to do mine, different pics would be great! Thanks
Old Mar 11, 2003 | 03:30 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Here's mine (with the alpine nav unit beside it). The MDF box has since been painted black. Amazing they both fit in there (barely).
Old Mar 11, 2003 | 06:32 PM
OMEGATLC's Avatar
OMEGATLC
Default Hope this works
Old Mar 11, 2003 | 06:53 PM
ares's Avatar
ares
Veteran
yeah I plan to take one of the mailbox slots for equipment, but Im gonna keep the factory door on it so I can conceal it back to stock, and perhaps confuse a theif on where the changer is.
Old Mar 15, 2003 | 09:02 AM
KJ-350's Avatar
KJ-350
Default Re: Hope this works
Originally posted by OMEGATLC
is the OEM trim plate around it? or did you have that made and covered to match? if its the OEM plate can you please take a min to measure that opening and let me know what they are? Im trying to see if my Kenwood changer is going to work in there or not? Also, did you have to cut or mod anything in there to mount it?
Old Mar 15, 2003 | 03:24 PM
OMEGATLC's Avatar
OMEGATLC
KJ-350:
The installers created the opening for the changer. Given the depth of the compartment inside, after its removal no other alterations/cutting had to be done.
Old Mar 28, 2003 | 10:02 PM
lemans's Avatar
lemans
Cool
That is exactly what I wanted to do. Do you know if it possible? I have not seen the changer in that location with the door still being used. If it works that woud be perfect.
Old Mar 29, 2003 | 04:17 AM
rouxeny's Avatar
rouxeny
The problem you may encounter is with depth. I had a DVD player I wanted to fit that was a little larger than DIN sized and it was too long to fit well.
As long as that requirement is met, mounting something while maintaing the cubby door shouldn't be that difficult. Try pulling out one of your cubby holes and making some test measurements. It would likely require cutting off the back parts of the cubby.
Old Mar 29, 2003 | 07:59 AM
lemans's Avatar
lemans
Cool
If cutting out back of cubby is all it would take, that would be fine with me. I will check that out. Thanks for thr response.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
