Where to install two amps!
Old Oct 11, 2006 | 12:45 PM
freemanjc's Avatar
freemanjc
Default Where to install two amps!
ANybody put thier amps in the cubbys behind the seat. I am thinking about putting them there but was unsure if the amp would over heat or not!
Please let me know wat you think!
R,
Julius
By the way my amps are
Hifonics 1206D Mono
Alpine F345
Old Oct 11, 2006 | 12:51 PM
james840a's Avatar
james840a
You should be ok putting them there. There couple guys on here that have there amps in the cubby behind the seat. Search Paul350z, he has pictures of his set up in the thread. I have my head unit brain, navi, PXA-H701 unit in that cubby and they are fine.
Old Oct 11, 2006 | 12:53 PM
masterj26's Avatar
masterj26
I have my amps behind the driver seat in the cubby and have had no problems, JL 300/4 and 500/1
Old Oct 11, 2006 | 12:54 PM
freemanjc's Avatar
freemanjc
Thanks James
Can you or anyone else tell how to get the 10 inch bracket removed from behind the seat. I don't know what plastic peices pop open to unsrew the metal brace thatis supposed to hold the subwoofer in the cubby!
Old Oct 11, 2006 | 01:29 PM
james840a's Avatar
james840a
Here is a link that i used when i first did mine. There might be other how-to out there but this is all i have at the moment.
http://liljerk.morpheus.net/350Z/rear_speakers/
Old Oct 11, 2006 | 01:40 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Two amps are easy.
You have to remove the kick plates, each side plastic part covering the tiny windows and down, the passenger's cubby, and then two large pieces that make up the speaker bridge and the actual cover over the speaker/cubby area removing the 12VDC jack cable.
Old Oct 11, 2006 | 02:31 PM
Interlagos Fire's Avatar
Interlagos Fire
Paul,
This may sound dumb but where do you connect the fan to? on the amp itself? Also, I really like the way you mount the amps on top of each other and I want to do the same thing, now was it stackable from Infinity, or did you made the mount rack yourself?
Joe
Old Oct 11, 2006 | 04:12 PM
Swiffer's Avatar
Swiffer
Originally Posted by Interlagos Fire
Paul,
Joe
The rack was homemade. I made one identical to his. (Thanks Paul for the idea)
Old Oct 11, 2006 | 06:39 PM
masterj26's Avatar
masterj26
+1 Paul inspired my amp rack too!!!
Old Oct 11, 2006 | 07:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The rack is just four 1/4" thread rods which are available from your local helpful hardware man. The fan is powered from the turn-on signal. I measured the current draw by the amplifier's circuits and bought a fan small/quiet enough that it didn't draw too much of the remaining power from the headend. The thing blows a gentle breeze between the pair of amps.
kyin
Oct 15, 2015 05:54 AM
