Constant Battery Draw....HELP!!!!
Old Nov 15, 2006 | 08:06 PM
gt3's Avatar
gt3
Sounds like the cap...try taking it out and see what happens.
Old Nov 16, 2006 | 02:55 AM
azula's Avatar
azula
will do, and thanks for the tip on the relay, i'ma check that out.
Old Nov 16, 2006 | 05:10 AM
350zspl's Avatar
350zspl
replace your capaciter with a battery in the trunk
inexpensive go optima
money not an issue go stinger
install a a stinger isolater relay under hood
it has 2 connectiions that go right between your power wire (hopefully your at least using a 4 guage power wire)
the other 2 connections are a ground off the relay , and a trigger power 12 volt source
with car not running
this will allow your stereo to run off the battery in the trunk and when that battery is drained it shuts system down so the power is not drawn from front battery under hood and car can always start
with car running both batteries will charge at same time
cap is your problem IMO , might be defective
a stinger battery from being used lets say at 14 volts till your relay shuts it down , now start car and the stinger will reach back to 14 volts in about 3 minutes
remember the alt will charge the battery with least resistance 1st
good luck
here is a photo of 2 trunk stinger battery set ups
and the under hood relay, with 150 amp circuit breaker by stinger
Old Nov 16, 2006 | 02:17 PM
azula's Avatar
azula
350zspl, thanks alot for the info...i will also take that into consideration. where can I purchase a relay from? and how much do they cost?
Old Nov 17, 2006 | 05:50 AM
350zspl's Avatar
350zspl
we sell them at our shop
retail about $50
if your handy you can intsall yourself
see photo it just splits between power wire , then run a 16" 14 guage ground off one end , and 12 volt off the other end
simple but effective
i got an extra one about 3 months old $25 shipped , it is the one in the sample photo i added to this post out of my 96 impala
if you want a new one go new , if you want a used one let me know
we sell caps at the store too , i am not saying caps are bad
but dollar for dollar battery is better
Old Nov 17, 2006 | 06:36 AM
james840a's Avatar
james840a
+2 for the cap! lol. i really hope that's the problem because that would be the simplest fix.
to found out if it is the cap, take it out of the loop and connect the power. then run it for couple days. If you continue to have the same proplem then it is not your cap, if the proplem goes away then it is your cap. With those size amp you have listed, you really dont need a cap. Caps are used to store power, so when the amp has a sharp note(bass) to hit, that the amp has the power right then to draw from, instead of drawing it from the long distance from the battery. If you find that it is the cap, then you can do the simple relay setup that 350zspl posted and that should fix your proplem of power drain when your car is setting.
For me, im pushing 1.3kilowatt of power with a 1.5cap w/built in relay, on oem battery and havent had a proplem, plus i drive it everyday too.
Hope you get it fixed
Old Nov 17, 2006 | 10:38 AM
350zspl's Avatar
350zspl
you in ft lauderdale
in live in delray beach
i work at a stereo shop on Saturdays by Hardrock Casino in Davie
come to my shop
i will diagnose what is your issue
and best route to fix
Saturdays 10 am to 6 pm
954-581-8189
Travis
350zspl
Old Nov 17, 2006 | 10:39 AM
350zspl's Avatar
350zspl
were have you been going to give your audio business to ,that got you in this situation ?????
Old Nov 17, 2006 | 12:14 PM
topgear's Avatar
topgear
I just installed this one 12VDC/30A SPST Automotive Relay from RadioShack for controlling the turn on/off of a amp cooling fan. $6.49 + personal labor.
Old Nov 17, 2006 | 01:46 PM
james840a's Avatar
james840a
Topgear, that relay wont work on the main power line. You need a higher amp relay like 350zspl has, youd fry that 30amp relay in a heart beat in line with your amps and battery.
But they do work for what you got going for the fans and light amprage devices.
Old Nov 17, 2006 | 03:14 PM
azula's Avatar
azula
350spl sorry for the delay, but i'm am really really REALLY happy to find out you're local. I have been going from audio shop to audio shop looking for someone I can trust. Sound Advice did my amp/speaker/subwoofer install and 595 auto accessories diagnosed my problem (it turned out to be the cap, no surprise)....they charged me 89 bucks for something I told them to check out, I guess I live and I learn. So I'm going to pick up the car tomorrow with the lack of a cap. I really like the cap I had because it was "showy" and it went with the color of my car. So I will definitely be at your shop to get my relay installed, what's the name of your shop? I stay in Plantation so you're not far from me at all.
Old Nov 17, 2006 | 03:25 PM
azula's Avatar
azula
here is a pic of my trunk....
that's the capacitor that stopped working. it had a LED display which cut out on me after the first 2 weeks of use. However, I think I'm going to get another, but this time, I'll make sure to keep the receipt...lol.
Old Nov 18, 2006 | 06:50 AM
ZmanZZZ's Avatar
ZmanZZZ
Nice trunk! I've never seen that cap before. Who makes that??
Old Nov 19, 2006 | 05:21 AM
azula's Avatar
azula
well, i picked up the car yesterday and it was the cap. It's parked in my garage since yesterday (without the battery charger attached), i won't drive it until tuesday or wed. just to make sure everything is working. 350zspl, i'll be seeing you this week...
Old Nov 20, 2006 | 06:56 AM
350zspl's Avatar
350zspl
i been to five 9 five for an spl show ,i know them
Precission Performance is were i work on Sat
1 block south of Griffin on 441 west side
i work there Saturday's 10 am to 6 pm
954-581-8189
Travis is my name
i work another job mon thru fri in Boca
call me here so i can schedule your appointment for any Sat when i am there
800-777-8665 ext 2242
mon thru fri 8 am to 5 pm
call me and we can get you some hearing loss in no time
Old Nov 20, 2006 | 09:53 AM
VO...'s Avatar
VO...
Administrator
clean set-up
Old Nov 21, 2006 | 06:53 AM
azula's Avatar
azula
Thanks a lot, now I just have to get it to work....lol. I'm getting custom kicks built currently, but that's a new topic....haha.
Old Mar 4, 2007 | 04:02 PM
  #38
azula's Avatar
azula
Well I installed a new Stinger capacitor and guess what, its doing the same thing...so I disconnected it. Now there is NO possible way that this capacitor is broken too....could it possibly be something that is not connected right? The capacitor should not be killing my battery like this....obviously.
Old Mar 4, 2007 | 04:32 PM
  #39
sq40's Avatar
sq40
Capacitors DO draw some bit of energy,, not enough to do what is hapening to you though. I would remove ONE component at a time from your system till you find the part that is drawing the juice.
Old Mar 5, 2007 | 03:08 AM
  #40
azula's Avatar
azula
it is definitely the cap....the first time the battery was dying we disconnected each component of the system to see, and it came down to be the cap. i didn't have a cap for a period of about 2 months, with no problem. i put a brand new cap back on and now my battery is dying on me again...
