Speed is reading double on my avic n1
i finished installing my stereo tonight everything worked great other then the speed reading is reading double on the speedometer. I hooked up to the white wire on the middle plug. the middle plug has 2 white wires one with a strip and one with out. I hooked it up to the one without the strip. I know i read somewhere that there is a 8 pulse signal and a 2 pulse signal, just wandering if i hooked it up correctly.
It sounds like you used wire that was twice the gauge it was supposed to be, so the HU is getting double signal. Try a thinner wire to cut back the signal throughput.
There is a flaw in your reasoning, wire is circular, so you can't just cut in in half. I believe there is a calculation somewhere involving pi!
What no flux capacitor?
That was totally my mistake. So, something more like:
((pi*r^2)/2)*C
Where C is the current circumference of the wire. That should yield the new diameter, in radians, which you'll need to calculate the gauge from.
... I hate myself.
((pi*r^2)/2)*C
... I hate myself.
Tochigi_236
Sep 27, 2015 03:40 PM
