My little setup with CF speaker pods
Thanks guys.
Lakersfan:
Yes the tweeters are inside the stock location.
Kazuma:
Yes, I hated to have lost that space, but I did not want my amps exposed to the public if you know what I mean. I still have to secure those in there because they are moving. You're thinking of running the sub amp to the Bose sub or are you changing that sub out? I think it would make the Bose stronger, but no real thump. I also like the Bose sound, but I hate the lack of thump. I'm not trying to blast a neighborhood, but I like to feel a little something. Both of those amps are set to about 1/3 of the power.... I'm serious. The sub setting on the alpine deck are usually any where from 0 - 6.... It is STRONG. If you are thinking of changing the sub out, I'm sure you will notice a difference. Of course I think that a new deck will help as well.
JDMFairlady21:
Right. I would have loved to have done more custom work in there, but honestly I don't roll ($$$) like that. I was happy to just have changed out the stock speakers. I don't know how the rest of you on this forum do it.
Those pods are tight... they really shine in that setup.
Kaue
Lakersfan:
Kazuma:
JDMFairlady21:
Kaue
Yes I will probably be replacing the headunit with something, not sure what yet, I'd like to keep it double din. The audio controls on it aren't good either, I could probably get it to sound better if there were better controls for the speakers.
I'm definitely not trying to blow a neighborhood away either, but I want my bass to thump and rumble, which the Bose woofer just doesnt do.
question... and I am not an audio expert by far;
In regards to the 10" sub enclosure behind the driver seat, I was told that this was a "free air" setup.. as in, that bracket only lets you mount the sub, but unless it was a "free air" sub it would not sound good. Is this enclosure sealed? Or is your sub free air?
*excuse my lack of knowledge and verbage
I will take pics of the sub without the cover for you, rkd350z... other than that the others are in the beginning of the thread.
Kaue
I'd like more info. on the sub setup as well. Can you buy this Dynomat spray-on stuff to DIY? I've got a sub on the way but no enclosure yet; be cool if I can turn that area into a sealed enclosure with just some spray-on stuff.
Good luck
Kaue
So I ended up buying a similar infiniti sub since the space is small behind it.
Only problem now is that I get a bad rattle from the enclosure. I took the cover off which helped somewhat but still cant seem to get the rattle out. There is little strips of dynamat on the enclosure itself but not a lot. Do I need a lot to keep the rattling out?
I'll be pulling the sub out and checking it tomorrow for anything wrong.
350Z_Al
Oct 29, 2020 07:44 PM
