a really really simple G install :) pics
Old Dec 6, 2006 | 11:28 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
Default a really really simple G install :) pics
just got done with antoher G35...and perhaps my most simple install to date.
goals:
1. good sound quality
2. retain spare tire, clean install in trunk to save as much space as possbile
originally, the customer prolly just wanted the amp bolted to the back of the seat, put in the 4080 box, and thats it...but instead, i decided for the same price, i will make it look a little better.
The customer DID NOT need the rear seat pass through due to a baby seat always int he car.
lets get started:
signal starts off at an eclipse AVN5500 double din nav unit, flushed into the double din finisher, note the Eclipse IPOD controller's connector in the upper cubby
a pair of DLS ultiamte UP6 two way component make up the front stage, the tweeters are flushed into the factory kick panels, and the mids are sealed in cups in the door, the doors are dampened as well
moving on to the trunk, a 4080 box housing an elemental designs 11kv.2 10" sub sits on the passenger side, while the amp rack housing a DLS classic CA51 5 channel is upfront, it only takes up about 3" of trunk space, and retains full access to the spare raised infiniti logo cover conceals the amp most of the time. the amp is bi amping the front components, and sending about 300 watts to the sub
with the cover off, you can see the exposed internal circuitry of the CA51 behind plexiglass
and of course, a pic of the wiring behind the amp rack:
overall it sounds really good acutally for hte budget and install, and wouldnt you agree that it looks better than if just an amp was bolted to the back seat with the wiring exposed?
Old Dec 6, 2006 | 11:38 AM
RunyonAve's Avatar
RunyonAve
very clean.
Old Dec 6, 2006 | 11:40 AM
first350's Avatar
first350
looks good - do you always make your own parts for every install, or do you have them pre-made from previous installs? (I'm talking about the sub enclosure and amp rack)
thanks,
Peter
Old Dec 6, 2006 | 12:27 PM
sanf's Avatar
sanf
if I lived in CA. I would send my car right over to your place no doubt
Old Dec 6, 2006 | 01:43 PM
05-Z's Avatar
05-Z
enclosure looks great. how much of a difference in imaging with the DLS drivers mounted in the door vs kicks?
Old Dec 6, 2006 | 02:18 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i make my own each time, if yo look through my installs, you will notice i try not to do the same thing each time, that way, i can stay creative and the customers arent getting something that someone else already have
imaging in the doors isnt as good as kicks, not even close, thats for sure, but witht the tweeter down low, it helps a little and is better than stock, staging ist he same as kicks, very high, above dash level
Old Dec 6, 2006 | 03:44 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
looks great!
Old Dec 7, 2006 | 08:48 AM
dannichols's Avatar
dannichols
Very clean. I love the locations you set the components and subs in.
Old Dec 7, 2006 | 09:50 AM
THE TECH's Avatar
THE TECH
Nice.
350Z_Al
Oct 29, 2020 07:44 PM
