Tach signal
Old Dec 8, 2006 | 04:46 PM
Casuale17's Avatar
Casuale17
Default Tach signal
I have a TraqMate data logger and would like to tap into the tach signal so that I can log RPMs. Can anyone help me out with finding a good place to tap in to get a tach / RPM signal?
Old Dec 8, 2006 | 04:55 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Old Dec 8, 2006 | 05:15 PM
first350's Avatar
first350
if that doesn't work, you can grab the Tach signal wire where the wiring bundle comes into the interior, behind the battery (Check the nitrous section - lots of ppl use the tach signal for window switches)
-Peter
Old Dec 9, 2006 | 06:18 AM
SungNamZ's Avatar
SungNamZ
I have the Zeitronix unit and got the RPM signal by tapping into the wiring harness under the dash going to the ECU. You need to find out which wire provides signal from #1 cyclinder. Check with your local service department as ECU pin number and wire color have probably changed since doing mine in 2004.
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
