Fyi with Key fob (lock/unlock device)
Old Dec 10, 2006 | 07:50 AM
350zz053's Avatar
350zz053
Default Fyi with Key fob (lock/unlock device)
I saw a post where someone asked why his horn wasnt honking. And no one really knew the answer. some of you might already know so sorry for wasting your time
When you hit the lock button the horn honks and lights blink at the same time. But, if you hold them (lock/unlock) down, it will disable the horn, and the lights will only blink. My guess is so you dont have to always have the horn honk when you lock your doors
Also, im sure most of you know this already. If you hold the unlock button on your keyfob (the lock/unlock device), the windows will go down. and if you stick the key in the key hole and turn, it will go up.
Thats all!
Old Dec 10, 2006 | 08:04 AM
rockinbboy's Avatar
rockinbboy
I like it when my car honks. That way I know I locked my car without having to look for the blinks. But good to know none the less. Window trick is kewl too..I've done it a couple of times. Are they supposed to roll all the way down?
Old Dec 10, 2006 | 08:12 AM
CRIDDA's Avatar
CRIDDA
If you keep holding the unlock button it will go all the way down.
Old Dec 10, 2006 | 08:15 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by 350zz053
I saw a post where someone asked why his horn was honking. And no one really knew the answer. some of you might already know so sorry for wasting your time
When you hit the lock button the horn honks and lights blink at the same time. But, if you hold it down, it will disable the horn, and the lights will only blink. My guess is so you dont have to always have the horn honk when you lock your doors
Also, im sure most of you know this already. If you hold the unlock button on your keyfob (the lock/unlock device), the windows will go down. and if you stick the key in the key hole, it will go up.
Thats all!
Actually, you silence/unsilence the car honk by holding BOTH lock and unlock at the same time for a few seconds.
The windows only go up if you put the key in the keyhole on the door and turn it in the lock position and hold. They also go down if you turn it to unlock position and hold.
Old Dec 10, 2006 | 08:36 AM
350zz053's Avatar
350zz053
crap i just edited that. I wrote it wrong, i guess thats what drinking till 3am and coming to work at 7 does.
lolwatbro
Oct 9, 2021 04:58 AM
Siqcology
Sep 18, 2019 01:45 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
RWDBajan
Sep 17, 2015 04:52 PM
