Help with Amp Install
Old Dec 13, 2006 | 11:35 AM
paul1994's Avatar
paul1994
Question Help with Amp Install
Hey all,
I am about to install my Alpine amp to run 1 10'' Kicker sub. I am currently running a kenwood X-990 headunit with the bose stock sysytem.
My question is where is the best place to put the Amp. My idea is to place it under the passenger seat and run the power through the kick panel, But where do I ground the AMP? do I run a ground cable directly from the battery or do I ground it somewhere on the chassis?
I plan on using 8ga wire for the Power but what gage for the ground.
Thanks for you guys help in advance.
Old Dec 13, 2006 | 12:43 PM
Interlagos Fire's Avatar
Interlagos Fire
I have it behind the driver seat in the cubby, in fact, got two in there and plenty of place to ground, but I got no Bose sub to worry about, just had to remove about 14 nuts to get to the metal bracket, that's somehow there eventho I have no Bose and you have to remove all the plastics as well.
Under the seat many not be ideal when it comes to rainy weather etc.
Where are you planning to put the sub? If you're gonna get something like the Zenclosure or built your own for the trunk, then you might as well remove the Bose sub and put your amp there.
I got 8 awg for power and ground, should be fine.
Old Dec 13, 2006 | 12:54 PM
paul1994's Avatar
paul1994
I have a zenclosure box, which is in the hatch. Since I still have the Bose system installed with an aftermarket headunit. i will just add the Sub and AMP.
But where did you run the ground? From the battery compartment or to the Chassis.
Old Dec 13, 2006 | 01:41 PM
Interlagos Fire
For me, ground for the amps is bolted to a screw in the cubby, you will see it once you look in there, if I remembered correctly you don't even need to drill, just put a bolt and a nut in the hole and that should be fine, or, the bolt and nut was already there? I have a bad memory sometimes, but if it's not already there you can easily supply your own.
I don't even remember having to sand down an area for the ground, but if yours is painted in that area just sand it down to bare metal.
Only thing is, you should tune your amp BEFORE mounting there because the cubby is not always the easiest place to tune your amp after it's fixed in there.
I can try to take a pic for you if it helps, but since I don't drive the Z to work and it's already dark when I get home, I will try to take one tonight and see if it would come out clear.
Old Dec 13, 2006 | 02:23 PM
paul1994's Avatar
paul1994
Thanks, I appreciate if you could do that..
Old Dec 13, 2006 | 04:06 PM
Interlagos Fire
ok, sure.
Old Dec 13, 2006 | 05:53 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
And understand that the gas tank is mounted under that area ... and if you put a hole in it that would be a bad thing.
(it's been done by people here)
I mounted mine to the lower front edge where the subwoofer mounts and to the rear tab where the stock luggage cubby would have been.
Old Dec 13, 2006 | 07:50 PM
Interlagos Fire
Here's the shots of the grounds. It's not as Fancy as the above picture
Attached Thumbnails Help with Amp Install-img_1548.jpg   Help with Amp Install-img_1550.jpg
Old Dec 14, 2006 | 06:52 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That's about there my ground ended up too.
Thread rod is fancy?
Old Dec 14, 2006 | 08:53 AM
Interlagos Fire
lol, had to use thread rods since I got two different brands, a Kicker ZX300.1 on top and Phoenix Gold R804 below. I should have kept the brands consistant so it look better.
Old Dec 14, 2006 | 05:20 PM
paul1994's Avatar
paul1994
Hey THanks Guys.. I appreciate the help. since I have a small amp I think I am going to put it behind the passenger seat, untill I redo all the speakers.
Old Dec 14, 2006 | 06:04 PM
stereoneeds's Avatar
stereoneeds
go with 4 gauge power wire. and your ground should be the same gauge as your power wire, so go with 4 gauge there too. i went behind my driver's seat like everyone above, and love it. with the panel snapped on, you cant even tell that theres an amp there.
kyin
Oct 15, 2015 05:54 AM
