super quick front speaker wiring question
There are two factory wires running into the front speakers: one red, one blue. Which is positive and which is negative?
Well, I'm going to be tapping into the harness behind the headunit with the wires from my amp (to use the factory wiring from that point out into the doors), and I think the wires go through other connectors and change color or something between the HU harness and the doors, so I need to know which is +/- as they are wired from the factory.
to check which is - & +
take a 9 volt battery
take your midrange speaker out of the door
it will unplug
but don't unplug it
cut the both wires that run from the plug about 2" in length
now you shold have speaker out of car and in hand
the factory plug should still be attatched to speaker and you should have left 2" of wire coming from plug
strip 1/4" off each 2" lead
take your nine volt battery and touch at the same time one color wire on the + terminal and the other on the - terminal
when the speaker moves out NOT IN than you have found out which color wire is - & +
if speaker moves in than switch wires and now it should move out
it will unplug
but don't unplug it
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Beater350z
Sep 9, 2015 03:36 PM
NYGiants0186
Sep 8, 2015 10:37 AM
