amplified Antenna?
Old Dec 27, 2006 | 07:24 AM
dennisj's Avatar
dennisj
Default amplified Antenna?
Is the stock Z radio antenna amplified? I just installed a new head unit and the FM reception sux. Going to pull it back out tonight and check the wiring. I had a Blue UFO wire that I didn't hook up and that must be the power going to the amplified antenna (Assuming it's is amplified)
Thanks
Old Dec 27, 2006 | 10:08 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yes it's amplified.
LG is color code for light green.
G/W is a dark green wire with a white stripe.
Old Dec 27, 2006 | 10:10 AM
dennisj's Avatar
dennisj
I found the answer out in the Service manual.
It does have an antenna amp.
Old Dec 27, 2006 | 04:48 PM
Zd3mon's Avatar
Zd3mon
Is the amp only for the stock headunit cuz after i put an aftermarket headunit in the reception sux too!
Old Dec 28, 2006 | 03:14 AM
dennisj's Avatar
dennisj
It's for any head unit that uses the stock antenna. Sounds like you need to do what I just did and pull it back out and connect the wire that powers the antenna amp. It's in the bigger connector and I believe it was blue with white stripe. Connect it up to the power anntenna lead of your new head unit.
Old Dec 28, 2006 | 08:11 AM
VO...'s Avatar
VO...
Administrator
You will need to suppy the antenna booster pwr wire with 12vdc before it'll turn on.
Old Aug 26, 2012 | 02:05 PM
rey rey_10's Avatar
rey rey_10
bumping a old thread..
I am having the same issues.
any one have pics of this?
Should I connect the blue and white wire to the blue wire that would be used as remote start for a after market amp?
Old Aug 26, 2012 | 04:49 PM
coanan's Avatar
coanan
YES
Old Aug 26, 2012 | 05:59 PM
rey rey_10's Avatar
rey rey_10
Thank you!
reno56
Interior
17
Nov 20, 2015 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
