Navigation is DEAD!
Old Jan 4, 2007 | 05:13 PM
njabe567's Avatar
njabe567
Default Navigation is DEAD!
My oem navi wont turn on? the door the opens to the navi works fine but the navi system its self wont power on. Couple days before it stopped working completley it would flicker on and off and then go back on. Anyone had this issue? does it sound like a fuse? if so where is the navagation fuse located? thanks
Old Jan 4, 2007 | 05:16 PM
JasonZ-YA's Avatar
JasonZ-YA
try temporarly dissasembling the center dash section! I had an issue where the door would open but not exacly quite the entire way. it needs ever little mm to open then it powers on the screen! i removed the dash and opened it up by pressing the button outside and when it opened all the way the screen came on! the door is retarted! it has to open all the way!
- j
Old Jan 4, 2007 | 05:17 PM
JasonZ-YA's Avatar
JasonZ-YA
Then if thats the case, play with reassembly and you should get it to work! if its more than the door not opening all the way then good luck! cause other than that i would think you would need the brain that the door is attached too replaced!
Old Jan 4, 2007 | 05:20 PM
njabe567's Avatar
njabe567
is disassembling the center dash hard?
Old Jan 4, 2007 | 05:23 PM
JasonZ-YA's Avatar
JasonZ-YA
no not really! okay this is what you do? you there?!
Old Jan 4, 2007 | 05:24 PM
JasonZ-YA's Avatar
JasonZ-YA
Step 1: where the nav buttons are! pull up on that! you can use your finger nails if you want get a screw driver! but i dont like screwdrivers near the screen! so i would use your finger nails and pull!
Old Jan 4, 2007 | 05:25 PM
JasonZ-YA's Avatar
JasonZ-YA
Step 2: then pull up on the part around the shifter! it just pops right up!
Step 3: disconnect the wire behind the a/c controls! that ribbon wire goes to a weird white box called the unimeter!
Old Jan 4, 2007 | 05:27 PM
JasonZ-YA's Avatar
JasonZ-YA
Step 4: there are about 4-6 screws that are visible now! the heads are looking right at you! you can tell they are holding the center dash in! remove those 4-6 and save!
step 5: pull up on the entire dash center section! once its kinda removed there are 2 wires connected to the upper three gauges! but i would say stop there and turn the car on and see if the nav door opens all the way and fixes the problem>?
- j
Old Jan 4, 2007 | 05:29 PM
JasonZ-YA's Avatar
JasonZ-YA
here is a link to another guy that did this! this one doesnt have oem nav but the pics should help for the rest!
http://liljerk.morpheus.net/350Z/dash_removal/
- J
Old Jan 4, 2007 | 05:57 PM
njabe567's Avatar
njabe567
awesome ill give it a shot.. thanks
Old Jan 4, 2007 | 06:00 PM
JasonZ-YA's Avatar
JasonZ-YA
no prob...let me know!
- J
Old Jan 4, 2007 | 06:01 PM
Ianmtx's Avatar
Ianmtx
Apparently Jason really likes exclamation marks.
Old Jan 4, 2007 | 06:06 PM
JasonZ-YA's Avatar
JasonZ-YA
ya know? i think i do!
Old Jan 4, 2007 | 06:08 PM
JasonZ-YA's Avatar
JasonZ-YA
hey, does your spacer allow you to still use the stock strut bar? or does it hit?
- j
Depravity
Oct 1, 2015 04:49 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Toby
Oct 14, 2002 12:25 PM
import-depot.com
Sep 12, 2002 01:31 PM
