Amp Behind seat
Old Jan 22, 2007 | 09:54 AM
mgntwo's Avatar
mgntwo
Default Amp Behind seat
What the easiest way to mount the amp in the stock sub location? Nothing to crazy with fiberglassing just normal work
Old Jan 22, 2007 | 10:02 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
cut out some wood for a platform mount plateform, mount amp whooolah.
Old Jan 22, 2007 | 10:31 AM
ZBigDog's Avatar
ZBigDog
Try a search for it theres tons of pics out there you can get the idea from
Old Jan 22, 2007 | 10:43 AM
Luscious Luke's Avatar
Luscious Luke
Like this.
Well, its not exactally in the same position you talked about, but its a good spot for it, and its lockable. Not to say a big screw driver couldnt get you in there, but its better than advertising your amp through your back window like allot of folks do.
Attached Thumbnails Amp Behind seat-z-amps-2.jpg   Amp Behind seat-z-amps-1.jpg
Old Jan 22, 2007 | 11:00 AM
dragone2717's Avatar
dragone2717
I just finished mine on Fri and it was alot easier then it looked. 15 minute was all I spent on it. There are 2 bolt wholes that you can use on the top to hang the back hinges with the stock bolts you take off from the bose submount. I have no idea why they put that submount there if it did not come with it.
Old Jan 23, 2007 | 06:22 PM
mgntwo's Avatar
mgntwo
thanks man
Old Jan 23, 2007 | 06:58 PM
first350's Avatar
first350
just posted this: https://my350z.com/forum/audio-and-video/244838-amp-install-w-pics-and-dimensions.html
gives you the general dimensions to build an amp rack.
-Peter
m_0g
Jun 3, 2021 10:05 AM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
