Subwoofer Install help/problem
Old Feb 1, 2007 | 12:05 PM
bay350z's Avatar
bay350z
Question Subwoofer Install help/problem
I got my box from wicked cas the corner hatch. I got the sub mounted but couldn't get all the holes on enought lip to tighten them down tight. I get this sound from the sub that I can't explain and it doesn't sound right. Like a extra vibration. COuld it be from a air leak? I tired it out of the box at low volume to not mess it up and its not there at all. If i put silicon or make a ring/spacer from MDF will that help. Also my drill slipped and almost put a small hole in the rubber, it sounds fine besides the other sound. Will that affect the sub. I am not sure if it went thorugh or not. I can see where it hit tore the rubber a little. I can take a picture when i get home later.
Thanks for the help. I have done other subwoofers and never had this before. At first I thought it was the wire inside so i shortened it. That didn't help.
Thanks a lot.
Old Feb 1, 2007 | 12:09 PM
Nazar's Avatar
Nazar
Thanks a lot.
use some foam gasket to make sure there is no leaks between the sub and the Box. It sound like you have a leak.
Old Feb 1, 2007 | 12:16 PM
bay350z's Avatar
bay350z
Thanks wil that help in the spots that the screw doesn't hold, can i just use the foam gasket and not put a screw there?
Where can I get foam gasket?
Old Feb 3, 2007 | 06:08 AM
Nazar's Avatar
Nazar
If the hole is stripped you may try that, But if it keeps persisiting PM me I will have you send it back and I can fix it here.
kyin
Oct 15, 2015 05:54 AM
