HELP with deck problem
Old Feb 7, 2007 | 09:42 PM
Hieu604's Avatar
Hieu604
Default HELP with deck problem
For some reason their is no power going into my deck and i check my fuse wat could cause this problem?
every other eletronic work but the deck.
I check my alpine deck and my stock deck both with the same problem
And i took the ground wire and start tapping the chassis 2 c if any power is their but no tiny spark sparked
Old Feb 8, 2007 | 04:12 AM
Lsmith9523's Avatar
Lsmith9523
Lets see,,,you said you checked your fuse....Now, did you check the fuse panel in the car and the inline fuse of the headunit(wire harness). I know for Alpine,,,the yellow usually has the inline fuse built in.
Also,,if you checked your stock headunit as well as aftermarket,,and no power ,,that narrows it down to the car more than likely. I hope this helps.
PS. Dont tap the ground wire for sparks,,,,,,get a meter and measure...
Old Feb 8, 2007 | 05:35 PM
Spike100's Avatar
Spike100
Originally Posted by Hieu604
For some reason their is no power going into my deck and i check my fuse wat could cause this problem? every other eletronic work but the deck. I check my alpine deck and my stock deck both with the same problem And i took the ground wire and start tapping the chassis 2 c if any power is their but no tiny spark sparked
Possible faults:
1) You're connecting to a power source that is not "hot." There could be all sorts of reasons for this (e.g., a blown fuse, connecting to the wrong power wire, etc.)
2) You have not established a reliable ground.
Since you report that the stock deck is not working (and if that is accurate… you know for sure), I would think you can eliminate a blown in-line fuse in the Alpine unit.
You really need to use a test instrument (to measure voltage and amps). Tapping wires (ground or hot) can introduce other variable (and even failures).
I do know how frustrating this can be, but I also know (from my own experiences) that you will get it working. When you do solve the problem, please post how you fixed it (to this thread). --Spike
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
