Change 06 console for 03-05?? Need a nav Z Vin # please.
Old Feb 25, 2007 | 10:06 AM
Z1truth's Avatar
Z1truth
Default Change 06 console for 03-05?? Need a nav Z Vin # please.
Hey guys,
I know this has been beat to death, but I have a 06 350 and I want to do a carputer and put the screen in the cubby w/t the hide away door. The spring loaded 03 hide away door won't fit the 06 as most of you know, its too small.
SO I need to see if I can change the entire 06 radio/cubby console for the 03-05 console.....and will it fit the 06.
My buddy at Superior Nissan asked me to get a Vin # of a 03-05 350 with Nav w/t cubby door and that way we can order the right one THE FIRST TIME!
I'm also going to order the 06 Nav console also,which Nissan didn't make with a door for the 06's, to compare the overall size and make sure the consoles are interchangable.
So is there someone that has a 03-05 with nav/recessed door that can PM me their Vin#???
I want to order this crap tuesday to get it by friday!
Thanks in advance to all that respond!
Old Feb 25, 2007 | 08:52 PM
Z1truth's Avatar
Z1truth
What ........no help from my Z brothers??????????? Anyone with a 03-05 nav 350Z????
Old Feb 25, 2007 | 09:04 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
its sunday not to many on sunday.
bump need help on this too
Old Feb 25, 2007 | 10:55 PM
vispre's Avatar
vispre
subscribing... been waiting for someone to try this
Old Feb 26, 2007 | 08:02 AM
usmanasif's Avatar
usmanasif
Scroll the forum. A thread was posted about that just last week where a member got the '06 w/ nav center dash trim to install a screen in his 03-05. Trim will include dummy nav control panel.
Old Feb 26, 2007 | 06:54 PM
Z1truth's Avatar
Z1truth
I saw that bro.......but I would rather have the NAV with a hide away door like the 03 -05 models. The 06 NAV model has NO DOOR! And $260 for a non functional nav panel seems alittle excessive to me. That's why I need a Nav /hide away door 03-05 350Z model vin# to make sure I get the correct one to see if it even fits the 06 dash.
If it doesn't fit then I'm relagated to that other setup.
But I gotta try!
Old Feb 27, 2007 | 03:13 AM
Nucleus's Avatar
Nucleus
The radio is slightly not the same shape in 2006 than in 2005. The corners are rounder on the 2006. Therefore, the center console around the radio may not fit.
Rich
Old Feb 27, 2007 | 08:48 AM
Z1truth's Avatar
Z1truth
Rich
Just checked that out and you a 100% right .......DANG! In fact, the radio in the 06 dips into the temperature control panel below it un like the 03-05's being straight across!
So no chance of a 03-05 console swap!
Old Feb 27, 2007 | 09:00 AM
Z1truth's Avatar
Z1truth
Well after much research.......the 03 pod/cubby console with door will absolutely not fit the 06 model! DEAD ISSUE! So NO hide away cubby door opportunity at all! It's either Minispiders first option......
Or his second option and the nav buttons on the panel are not operational........
Which choice do you guys like.......
PS Should of just listened to MS in the beginning.......
Old Feb 27, 2007 | 11:07 AM
vispre's Avatar
vispre
Oh i thought you were gonna do a console swap.
(not just the upper console portion, but even the shifter area and the cup holders...)
I heard that works but Im not positive.
Old Feb 27, 2007 | 12:17 PM
Z1truth's Avatar
Z1truth
Too much cash to do everything......at least for me!
Old May 19, 2007 | 06:24 AM
CRAZY Z's Avatar
CRAZY Z
Yah you have to swap everything to make it work. I have just recently did this swap. Did you get 06 ac ***** to work?
Old Jan 26, 2008 | 01:19 PM
sukebe's Avatar
sukebe
Can you do the second option, with no door, but use the plain old, no button finisher from an 03-05?
Old Jan 26, 2008 | 02:19 PM
MarkM's Avatar
MarkM
nav cubby will fit the 06 car, just takes some work, I've done it! Only problem is the door won't close, but that doesn't bother me
As you can see the door doesn't fit well, but I just leave it open.....
Old Jan 26, 2008 | 04:34 PM
Kwame's Avatar
Kwame
^^^ Just wondering why you would swap to an older model cubby if you don't plan on closing the cubby door anyway?
Old Jan 27, 2008 | 03:46 AM
MarkM's Avatar
MarkM
1. to have a kenwood touchscreen, I didn't have nav at all, just the hinged door cubby
2. 03 nav cubby is so much cheaper and better looking imo than the 06 nav set up, where you not only need to buy the button panel to cover the gap, but it doesn't even work with aftermarket navs!
Old Jan 27, 2008 | 04:49 AM
Kwame's Avatar
Kwame
Gotcha ya. Thanks for the explanation.
Old Jan 27, 2008 | 08:20 AM
sukebe's Avatar
sukebe
NM, this guy did it.
https://my350z.com/forum/showthread....ighlight=cubby
lapham3
Oct 7, 2022 03:15 PM
