Do we need to use a higher level resistor for bass popping?
Old Apr 7, 2003 | 12:36 PM
jcru2000's Avatar
jcru2000
Default Do we need to use a higher level resistor for bass popping?
I have not yet tried the 1k resistor, i will do this today, but i play a lot of music with bass. so if this popping thing happens, i am wondering if i should switch to another, higher resistor. and what resistor would work if this holds true? thanks.
Old Apr 7, 2003 | 05:21 PM
abz123's Avatar
abz123
You shouldn't get any popping. I don't think anyone has experience any popping.
The problem has to do with erradict raising and lowering of bass and volume by the 'audio pilot' in system based on engine and environmental noise.
I think people have tried other higher resistors already with no success.
Old Apr 8, 2003 | 09:43 PM
bastard's Avatar
bastard
If your fronts are not crossed over they could make popping noises if your bass is really loud. Two solutions: use bass blockers at about the frequency your sub is set at (the inexpensive way) or buy an amp and use the high pass filter on it.
Note that you can make do with some capacitors from radio shack, if you know the correct uF. it's dependent on speaker impedance (ohms) and what frequency you want them crossed at. They wire in on the positive. Look for a crossover calculator, and look for the 6dB slope one.
All resistors do is make your speakers play quieter by turning power into heat.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
Alexreyes
Sep 30, 2015 11:30 PM
