HELP!! Amp question
Old Mar 7, 2007 | 05:27 AM
350Zrida's Avatar
350Zrida
Default HELP!! Amp question
Not really needing help, but I would like to solicit some opinions/advice.
I have just purchased almost everything for a new stereo and now I am stuck on wether or not to go with 2 two channel amps for the front door and rear speakers or 1 four channel to run them all. I already have the speakers. For the door I went with Polk MOMO MMC 6500 and for the rear deck I chose the Polk DB 675.
The amplifiers that I am considering for this are: 1 four channel Alphasonik PMA 4150, OR 1 Alphasonik PMA 2075A for the rears and 1 PMA 2150A for the front speakers. I already have an Alphasonik amp powering an Alphasonik subwoofer, so Im not willing to change my choices in amps.
Which setup should I go with??
Old Mar 7, 2007 | 05:40 AM
teh215's Avatar
teh215
I would go with a 2 channel and only use the front speakers.
Old Mar 7, 2007 | 05:49 AM
350Zrida's Avatar
350Zrida
why only the fronts?? I have a pretty powerful Sub (Alphasonik Mayhem PSW912) It puts out 2200W RMS and that will be on an amp feeding it 2K RMS. I know those Polks in the back wont be near as loud as the ones in the front, but I think that sub is going to be fcking LOUD! back there.
Old Mar 7, 2007 | 05:56 AM
teh215's Avatar
teh215
In addition to the sub, I would only use the fronts but, that is just my opinion based on the information that I gathered when I upgraded the audio in my car last summer. The rears don't really seem to do much since they fire into the backs of the seats
Old Mar 7, 2007 | 06:20 AM
AroundMyHorn's Avatar
AroundMyHorn
i installed new rear speakers and i love it. I would think it woudl sound kinda weird with no sound coming from behind me.
Old Mar 8, 2007 | 11:01 AM
350zspl's Avatar
350zspl
fronts only
IMO
rear is fighting your front stage
2 close to ear in the rear
Old Mar 8, 2007 | 11:45 AM
TurboTrey's Avatar
TurboTrey
I think that it doesn't really matter if you use a 2 or 4 channel amp. Just get something that is powerful enough for all the speakers. It sounds like you can either get 2 low power 2 channels or 1 high power 4 channel. I would go with the 4 channel to save space and time.
I am all about keeping the rear speakers. I think unless you are going with some real high dollar speakers you won't really lose any quality. I fade mine from middle to front and I think that the middle setting sounds 10x better than just the fronts. Fade it all the way to the front for a few days to try it out and then put it back in the middle and you will think you have a whole new sound system.
Old Mar 8, 2007 | 11:53 AM
350Zrida's Avatar
350Zrida
Okay..to further complicate things, the fronts are rated at 125W RMS while the rear 2 are a measly 60W RMS. If I put them all on 1 four channel those 2 in the back will get fried..right? Thats why I wanted two seperate amps, plus I read somewhere its better to have 1 amp per speaker...cant remember why though
Old Mar 8, 2007 | 12:02 PM
Quijano187's Avatar
Quijano187
^^ i just bought those same speakers in the front. I also bought speakers for the back rated at 80rms. I use JL 450/4 ... the front are 150 rms and the back are 75 rms.. I think this amp match up nicely to what i have. I know you dont wanna change amps but i wanted to let you know what i did and have.
Old Mar 8, 2007 | 12:41 PM
350zspl's Avatar
350zspl
no
if your stuck on front and rear set up
and 4 ch
get a RF punch 450.4
feed your fronts 150 rms clean
feed your rears 1/2 gain about 75 watts rms clean
i run a 2 ch type RF x2 to a pair of type rf 6.5 comps and 1.1" tweets no rear at all and front stage is sharing about 400 watts
Old Mar 8, 2007 | 12:51 PM
350Zrida's Avatar
350Zrida
'Preciate the input, but here is why I dont want to change my amp preferences...
Alphasonik 12 in. sub 2200W RMS-
http://www.alphasonik.com/mayhem.html
Powered by Alphasonik 1200DA 2000W RMS@ 2OHM- http://www.sonicelectronix.com/item_3660.html
I went with Polk for the front and rear soundstage and really want to match the amps up. There is a lot more stuff being thrown in my Z...rear back up camera, DVD, seperate Nav system, and extra battery.
JL makes solid products, but I wanted to go down the road less traveled here. I havent seen any Alphasonik stuff here anywhere and I like to "NOT" follow the crowd. I have a nice pair of Nakamichi 10" subs from waaaaay back in the day to prove it!
That amp sounds tempting because of the seperate front and rear power ratings, but I think I will just buy 1 amp for the front and 1 for the rear. The price difference is only $100 to have three amps instead of two.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
