What ya'll think???
Old Mar 14, 2007 | 06:24 PM
thumpboarder's Avatar
thumpboarder
Default What ya'll think???
Alright I'm tired of the Bose crap cutting in and out esp when its cold. Anyway I'm going to put a Z1 in the dash cause I got a very nice accomdation with Pioneer right now. Probably go back to my roots with the Diamond Audio hex series 6.5" components for the front and DA 6.5" coaxials for the rear.
Now comes the major fab work. I want my trunk area so I'm planning on trying to build a chamber in the stock location with 2 8" JL W7's. One in teh stock location and the other where the glove box is. I'm going to seal the whole chamber. then sound deaden it using the EDead paint. spray on some thin car carpet lay down masking tape and then fiberglass over it. I'm going to size up the box by the ole popcorn trick. Measure out 1 cu ft that way for each side. Hopefully I'll be able to do this for each and then finish off the enclosure. Any suggestions to make my life easier would be appreciated.
As for amps I'm planning on trying to use a jl 1001/1 for the subs and probably the jl 300/4 for my highs unless I decide to go the 450/4 route with my highs. I'm going to try to get an alumnipro either 5 or 15 farad capacitor to run it efficiently. I was going to try to make amp racks to mount the amps in the trunk on each side in those corners right when you open the hatch to the left and right.
Ya'll who have deadened your doors. Did ya'll remove that protective cover hiding all the holes and the window motor or did ya'll just deaden over it instead?
Old Mar 14, 2007 | 06:36 PM
Mike Wazowski's Avatar
Mike Wazowski
removed it
Old Mar 14, 2007 | 06:39 PM
thumpboarder
excuse me?????
Old Mar 14, 2007 | 06:44 PM
Mike Wazowski
forget what you asked already?
Old Mar 14, 2007 | 06:46 PM
thumpboarder
I figured that was what you meant after I posted, I asked a few quesiton somewhere in all the cluster of words
Old Mar 14, 2007 | 07:01 PM
tattoo60012's Avatar
tattoo60012
I just went over the top of it, but I deadened where I could reach through the speaker hole.
Old Mar 14, 2007 | 07:28 PM
05-Z's Avatar
05-Z
why are you seperating the subs? why not just one 10W7 in the rear?
regarding the glove box to make your life easier, have you seen nazar's enclosure?
Old Mar 14, 2007 | 07:36 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
8w7s in the stock locations hmm
Old Mar 14, 2007 | 08:31 PM
azula's Avatar
azula
Wow!!!!!!!!!!!!!!!!!!
Old Mar 14, 2007 | 08:56 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
the rest of the car is even more wow
Old Mar 14, 2007 | 09:06 PM
Sean's Avatar
Sean
brick, done any work on 240sx front speaker set ups? looking to put 3 driver set in or near each door
Old Mar 14, 2007 | 10:21 PM
thumpboarder
sending you a pm
Old Mar 15, 2007 | 07:09 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hey guys, to clarify, i did NOT do that Z...do a search and you can see some of the pics of that car posts a month or so back. he built ported enclosures in the cubbys with the port coming out of the small storage pocket...
the whole car is just amazing...
as for hte 240sx, yes i haev, door midbass, midrange and tweet in the kicks
b
