Wiring a Cooling fan
Old Mar 16, 2007 | 12:04 PM
mgntwo's Avatar
mgntwo
Default Wiring a Cooling fan
Hey guys im trying to add a cooling fan to keep my amps cool. Im trying to find the best way to wire it in. My first guess is tap into the turn on lead. Is this the best way? Thanks for the advice guys.
Old Mar 16, 2007 | 12:23 PM
redlude97's Avatar
redlude97
tap into the turn on lead to power a relay to run the fans off. Also make sure a diode is used so the backsurge when the relay turns off doesn't cause a popping sound from the subs
Old Mar 16, 2007 | 06:32 PM
tattoo60012's Avatar
tattoo60012
What redlude97 said is absolutely correct, if you try to go straight off the RTO lead you are forcing your head unit to power your cooling fan, and besides the excessive current draw from the fan motor, you can also introduce motor noise into the circuit which can and probly will backfeed to the head unit causing more problems for you than just hot amps.
Old Mar 16, 2007 | 07:23 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
well this depends honestly, if its a very simple CPU type of fan, chances are it doesnt draw nearly enough current to do anyhting to the RTO signal, if you are just using one or two, and only turing on one amp or so...
but, if you are using a crossflow, or mutiple fans or have multiple accessories to turn on, es absoltuely, a relay is the way to go.
i pretty use relays on everything, but just asying, from experience, doing one or two small CPU fans of a lightly loaded RTO wire is fine...
Old Mar 16, 2007 | 07:27 PM
tattoo60012
Oh absolutely, I couldn't agree more, I just assumed (there's that word again) that if he NEEDED a fan to take care of heat issues, that the fan would be significant enough to warrant a seperate circuit.
Old Mar 17, 2007 | 05:27 AM
mgntwo's Avatar
mgntwo
Im using a stinger pf2 fan, the larger of the two. the draw they say .3 amp. I have kenwood mp7028 head unit. What type of relay and diode should i use. There is also the idea of using the power antena lead from the head unit cuz that is also a hot wire.
Old Mar 17, 2007 | 07:49 AM
i8acobra's Avatar
i8acobra
Here's a little diagram I whipped together:
Old Mar 17, 2007 | 07:56 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I run a tiny 20 cubic feet per minute fan that directs just a puff of air between my amplifiers. Helps just a ton over natural convection. I was playing with an IR camera and should have thought to bust open the amplifier cubby and take some measurements - next time possibly.
My amplifier turn-on circuit is good for 0.5 amps. My amplifiers draw 0.1 amps meaning I have 0.4 (400 milliamps) left over for the little fan. I've heard no noise caused by the DC fan. I did the thermal load on my ~1200 worth of amplifiers with no fan in the subwoofer cubby and there wasn't going to be a problem. Being a belt and suspenders kind of guy - and living in SoCal's desert where the day time temperatures can hit 115 degrees - I thought the little fan would help.
There's a formula to calculate the heat produced in BTU and the insulation properties of various metals and materials. A fan helps strip the air from the heat sinks increasing their abilities to remove heat. The fan faces forward blowing air between the amps and toward's the empty hole where the subwoofers used to be. There is just the most gentle sound coming from the hole with the sound down and a soft breeze of warm air.
Diodes are placed reversed biased across heavy duty relays to reduce sparking between the armature leg as it closes. I've never known one to be use with any light duty relays - say less than a few hundred watts worth of load. It might be an audio tuners thing that I've never heard of though.
Old Mar 17, 2007 | 08:45 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
paul, having met you, why am I NOT suprised you have a IR camera haha
b
Old Mar 17, 2007 | 08:37 PM
KPierson's Avatar
KPierson
I want an IR camera!!!!
Thermography is cool!
Old Mar 17, 2007 | 08:54 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Thermography is hot!
(engine compartment - the bright spot is the radiator hose)
Old Mar 17, 2007 | 08:55 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
b
It's my uncles
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
Twenty4
Jan 17, 2016 01:20 PM
nanotech
Oct 2, 2015 05:02 AM
SharX59
Sep 30, 2015 10:54 AM
