Problem with component woofer and door panel
Old Mar 19, 2007 | 03:00 PM
playa6tnine's Avatar
playa6tnine
Default Problem with component woofer and door panel
I installed JL 6.5" components in the front. I used the stock OEM speaker as the spacer (the method where you cut up the oem speaker and mount the new one in it.)
anyway, after installation i noticed that the speaker grill on the door panel wasnt flush. i popped it out and saw that the edge, rubber surround part of the woofer was barely touching the inner door panel. BARELY touching. but still, if i put the bass up i'm sure the excersion would hit the panel and cause damage.
has anyone ran into this problem? is there a fix?
here are pics to show what i mean:
Old Mar 19, 2007 | 03:28 PM
NIZZMO's Avatar
NIZZMO
Why not buy 1/2 or 1 inch(cant remember) spacer's ? I have not seen this setup with the OEM speaker spacer tried b4 but it looks like damage ready to happen.
Old Mar 19, 2007 | 03:51 PM
Voboy's Avatar
Voboy
door pod time. for a pair of JL components I think you'd really benefit from some door pods.
Old Mar 19, 2007 | 03:55 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
make your own spacer, or door pod or kick panels
b
Old Mar 19, 2007 | 03:56 PM
savvy's Avatar
savvy
Buy door pods
Old Mar 19, 2007 | 04:01 PM
playa6tnine
yeah i was leaning towrads buying door pods...
am i only only one who has had this problem?
Old Mar 19, 2007 | 04:37 PM
TurboTrey's Avatar
TurboTrey
Buy some smaller speakers
Old Mar 21, 2007 | 06:20 PM
showtypeZ's Avatar
showtypeZ
I'm about to do mine this weekend. Best thing I can think of is making a slightly smaller spacer to give it enough clearance. Definitely wouldn't want to ignore this.
Old Mar 22, 2007 | 07:20 AM
StreetOC192's Avatar
StreetOC192
P
O
D
S
Pods, Pods, Pods!!!!!!!
Old Mar 22, 2007 | 07:41 AM
tahoe-man's Avatar
tahoe-man
I had the problem with my Bostons and they were also hitting the window when rolled down. I angled the spacer toward the driver and now both problems are solved. Pods/kicks would give you a better sound but this will work.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
