Help...what is this?
Old Mar 20, 2007 | 09:38 PM
2 SLY's Avatar
2 SLY
Default Help...what is this?
I just bought a 35th anniversary, and under the drivers dash there is a button that is connected to a wiring harness…I was curious as to what it is. I have clicked it a few times, but nothing happens. If I hold the button down for 3 seconds a green light comes on, and if I repeat the 3 second hold it turns off. When It is on I don’t feel a difference in the way the car drives (I thought it might be a chip) and the navigation screen is unaffected as well. Any ideas???
Old Mar 20, 2007 | 09:41 PM
HighwaySpeed's Avatar
HighwaySpeed
Welcome!
It might be a lojack type device used by the dealer, in case the car was stolen.
The dealer should have removed it, before you took delivery.
Bevo's Avatar
Bevo
idk, im guessing could it be alarm?
Old Mar 20, 2007 | 10:13 PM
i8acobra's Avatar
i8acobra
Follow the wires. Could be a valet switch for an alarm.
Old Mar 20, 2007 | 10:27 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
http://www.youtube.com/watch?v=u1Osau6Vl2s
Old Mar 20, 2007 | 10:43 PM
TheGest's Avatar
TheGest
Its cheese
Old Mar 21, 2007 | 04:09 AM
DavesZ#3's Avatar
DavesZ#3
I assume you bought the car used, correct? Must be something the previous owner installed.
Old Mar 21, 2007 | 06:08 AM
THE TECH's Avatar
THE TECH
No way for us to help you with something like that. Follow the wires and see what they lead to.
Old Mar 21, 2007 | 07:11 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
thast the self-destruct button...
Old Mar 21, 2007 | 07:58 AM
Blacryan's Avatar
Blacryan
It's just like the Pen from Jame's Bond. 3 Clicks armed, 3 clicks disarmed!
Old Mar 21, 2007 | 09:57 AM
2 SLY's Avatar
2 SLY
I will follow the wires and see where they go when I get off work tonight. I think the valet switch for the alarm idea might be a possibility. O and yes I did buy the car used, and the previous owner must have had it installed. I thought about trying to contact the previous owner, but the only way I know of doing that is through car-fax, and I don’t want to pay for that.
Old Mar 21, 2007 | 10:52 AM
TurboTrey's Avatar
TurboTrey
It looks like my old Clifford alarm button. You could program the alarm with a series of hits on the buttons.
Old Mar 21, 2007 | 11:44 AM
GOITOMGOOSE's Avatar
GOITOMGOOSE
you've been bugged!
Old Mar 21, 2007 | 01:42 PM
Trauma's Avatar
Trauma
Two words for you buddy - Al Qaeda. Run. Run far and don't look back.
Old Mar 21, 2007 | 03:53 PM
mg350ZR's Avatar
mg350ZR
ejector seat button
Old Mar 21, 2007 | 07:35 PM
2 SLY's Avatar
2 SLY
So I followed the wires, and under the drivers side kick panel the wiring harness is tapped into a factory wiring harness. I have not played around with the alarm yet (checking to see if it is a valet switch).
Old Mar 21, 2007 | 10:14 PM
Mazinger Z's Avatar
Mazinger Z
Maybe some aftermarket fog lights? THey might have taken it off and forgot to remove the button. I have the 35th - no such switch in mine.
Old Mar 26, 2007 | 05:32 PM
cvkatigbak's Avatar
cvkatigbak
its for the rocket launchers. duh..
Old Mar 27, 2007 | 12:40 AM
Lsmith9523's Avatar
Lsmith9523
Yo man,,,itz fo yo switches!!! 3 wheel motion FTW....j/king
Old Mar 27, 2007 | 12:45 AM
350Zrida's Avatar
350Zrida
I have the same thing in my car..yours looks like the prototype version though. When you hold it down like you said and the green light comes on, this means you are in "stealth" mode. Depress again, green light goes out, stealth mode inactivated.
Hope this helps!
