Installing Amp- 4 or 8 guage
Old Apr 12, 2003 | 03:27 PM
mucky's Avatar
mucky
Default Installing Amp- 4 or 8 guage
Hey everyone,
iwas told by the shop who is going to install my audio equip. that there is really no need to run 4 guage wire and 8 guage would be fine for the amps I am using, wich are JL 300/2 and Jl 500/1. I know 4 guage is about double the price,but is it worth it.
Thanks,
Matt
Old Apr 12, 2003 | 05:09 PM
Encore's Avatar
Encore
I would run 4ga for sure. I dont know the amperage draw of those two amps, but its got to enough for 4ga.
Old Apr 12, 2003 | 05:52 PM
bastard's Avatar
bastard
Default Re: Installing Amp- 4 or 8 guage
Originally posted by mucky
Hey everyone,
Thanks,
Matt
If I remember correctly, the 500/1 requires 40 or 50 amps. the 300/4 (similar to the 300/2) needs 40 or 50 as well. Use 4 gauge. 8 gauge can handle about 50 amps but as the length of wire goes up, the wire's capacity decreases. Use 4 gauge to a fused distribution block, then 8 gauge from the block to the amps. The 8 gauge runs need only be about 3-4 feet at the most.
Old Apr 12, 2003 | 07:16 PM
LS350Z's Avatar
LS350Z
Charter Member #56
Definitely run 4 gauge and with both those amps mounted in the trunk (taking the farthest distance in the car and assuming 100amps draw) you'll almost need 0 gauge (with maybe a foot or two to spare).
Old Apr 12, 2003 | 07:45 PM
BliZzZzZ's Avatar
BliZzZzZ
I would run 4 to a distribution block then run 8 from there out... Just remember to get a fused block and make sure you add up the amps for each fuse on the block, make sure it = the amout of amps that you put in the block right after the bat... I hope this is to confussing...
Old Apr 12, 2003 | 08:48 PM
Troy9's Avatar
Troy9
for the amps that you are using, I would go with at least 2 awg from the front to the distribution block and 4 awg out to the amps.
Old Apr 12, 2003 | 09:35 PM
alphared's Avatar
alphared
yeah, go with 4awg. That way if you upgrade, no need to rerun cables.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
