is there a difference between 7" and 7.2" lcd
Old Apr 16, 2003 | 05:38 PM
backagain's Avatar
backagain
Default is there a difference between 7" and 7.2" lcd
i am searching ebay for a lcd screen to go where the nav goes, but i dont' know if which one i need, i see both, 7" and 7.2" , which do i need ? or are they the same and people just say 7" for short ? thanks in advance...
ray
Old Apr 16, 2003 | 06:43 PM
abz123's Avatar
abz123
You need a 7" 'wide screen'.
A 7" widescreen will fit.
A 7" regular (4:3) screen will not fit.
Farenheit 7001 is an example of a non-VGA 7" widescreen.
The Xenarc is an example of a VGA 7" widescreen.
Old Apr 16, 2003 | 10:37 PM
backagain's Avatar
backagain
i know i need a 7" widescreen, but is there a difference between 7" and 7.2" ??? there are some on ebay, search for headrest lcd 7 . it wil pull up 7 inch, and 7.2. does anyone know this ? thanks
ray
Old Apr 17, 2003 | 07:34 AM
all_bark's Avatar
all_bark
Yeah, .2"
stick with the 7" only. Noone seems to be going with a 7.2"
OK?
Old Apr 17, 2003 | 09:13 AM
abz123's Avatar
abz123
It's not the screen size you have to worry about. It's the housing or case size. This varies from model to model.
The viewing area of a 7.2" widescreen should fit with no problem.
The plastic casing around it might have to be modified to fit depending on the brand you choose. Also if there are buttons, the Nav hole might have to be cut.
FYI, with my 7" Farenheit the sides of the casing were a snug fit.
Old Apr 17, 2003 | 09:22 AM
ares's Avatar
ares
Veteran
I dont think so... my 7" xenarc fits without casing only, and viewable area is exactly the size of the opening.
you need a 7" screen
not 7.2, not 7.1, 7.0
farenheit and xenarc are the only names Ive seen used.
Fixxxercask
Nov 9, 2015 11:10 AM
