NAVI Connector
Old Apr 19, 2003 | 11:43 PM
MR RIZK's Avatar
MR RIZK
Default NAVI Connector
Quick Question.
If you bought a Z without the navigation system does the Z still come with the harness for the nav system or is it installed when the option is chosen.
The reason I ask is that I have purchased a Z without the sat nav and wish to put one in (a aftermarket unit). When checking the manual it would make my life easy if the wiring loom is already in the car, so I can just tap the required wires from the loose plug.
I believe the plug for the sat nav is B104. Otherwise I will need to tap to other locations ie: Unified Meter and A/C amp Connector which does not give me everything I need.
It will only give me the VSS, Power, Ground, and Ignition. It does not give me Reverse or Illuminiation. I probally can get illumination from the head unit. Any ideas or help appreciated
Old Apr 20, 2003 | 09:41 AM
all_bark's Avatar
all_bark
look to chazzg for the incar pc. comes with nav, mpeg, dvd and other options for the same or less than the factory nav.
do a search in the private classifieds, it will show you what I mean. He plans on giving step by step instructions on how to install and tech support!
This way you'll get your nav and a whole lot more.
Old Apr 20, 2003 | 08:14 PM
MR RIZK's Avatar
MR RIZK
Okay I have a problem now. I pulled apart my dash to see if I have a VSS wire on my Unified Meter and A/C amp Connector. The white wire as described by skidazzle and others. I check the manual and it also says a white wire.
I do not have a white wire on the grey connector on the Unified Meter and A/C amp module.
Please be aware I own a Australian model not a US one. Any other suggestions to find the VSS wire besides the cluster ?
Pleask
Dec 21, 2021 03:17 PM
Vigman
Nov 17, 2015 04:34 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
EnjukuRacing
Misc.
Sep 16, 2015 06:25 AM
JasonZ-YA
Sep 15, 2015 07:19 PM
