Help..Alpine amp with Polk Momo
Old Apr 29, 2007 | 09:00 PM
jamaicanj's Avatar
jamaicanj
Default Help..Alpine amp with Polk Momo
I am checking to see if the Alpine MRP-F250 4/3/2 channel power amp has sufficient power for a pair of Polk MMC6500 components as well as a pair of Polk MMC650.
The specs on the amp:
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 40W x 4 (0.08% THD)
Per channel into 2 ohms: 50W x 4
Brigded 4 ohms: 180W x 2
The Alpine amp link: http://www.alpine-usa.com/US-en/prod...model=MRP-F250
The Polk MMC6500 link: http://www.polkaudio.com/caraudio/specs/mmc6500/
The Polk MMC650 link: http://www.polkaudio.com/caraudio/products/mmc650/
Any help would be appreciated
Old Apr 30, 2007 | 04:02 AM
jamaicanj's Avatar
jamaicanj
bump
Old Apr 30, 2007 | 04:19 AM
savvy's Avatar
savvy
well the MMC6500 handle 125w RMS and that amp only puts out 40RMS. Yeah it will run them but you will be running the amp at 100% which will distort that crap out of it. A general rule of thumb is you want to match the RMS of the speakers with the RMS of the amps. Or even better get an amp that overpowers the speakers so you can turn the gain on the amp way down and get super clean power. I would look at the F-545 amp to power those.
Old Apr 30, 2007 | 05:57 AM
jamaicanj's Avatar
jamaicanj
Do you think the alpine MRP-F450 would be sufficient?
Here is the link to the amp: http://www.alpine-usa.com/US-en/prod...model=MRP-F450
Old Apr 30, 2007 | 06:56 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
both amps are okay...what has been said is true, if you use an amp that matches the speakers rating, or exceeds it, andt uen it well, it will sound better...
but honestly, the MMC is nothing really special and espeically if yuo are just putting it in the stock location, i really dont think you need anywhere near the 125 watts its rated at, whcih acutally, come to think of it, is kinda high for htat speaker IMO
Old Apr 30, 2007 | 01:45 PM
jamaicanj's Avatar
jamaicanj
So, I should not need anymore than the MRP-F450 to run the Polk MMC6500 components as well as a pair of Polk MMC650?
Thanks for the patience in helping out the newbie
Old Apr 30, 2007 | 07:26 PM
jamaicanj's Avatar
jamaicanj
thoughts
Old Apr 30, 2007 | 09:56 PM
MinguezCD's Avatar
MinguezCD
Look into the MRVF545......Much bette for those speakers. If you got some Cash...Alpine PDX
Old May 1, 2007 | 06:06 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i am saying you will be fine, the polk SR are just you run of hte mill comp set IMO...and if you are on a budget, no need to spend more cash...the amp you are listing will make them sound pretty good, not t othe best of their ability but pretty decent.
if you were looking for really good sound qualtiy to the point of thinking about dynamic headroom and all that stuff, i think the SR is the line that you would be looking at from Polk, not the Momo stuff
b
Old May 2, 2007 | 08:40 PM
jamaicanj's Avatar
jamaicanj
b
I have the momos already so I am not in a position to change them just yet. I figured that the amp Alpine MRP-F250 was just not giving enough power as the midbass is a bit sorry desite all of the tuning.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
