Quick Amplifier and Subwoofer Question.
Old May 16, 2007 | 06:27 PM
snair2's Avatar
snair2
Default Quick Amplifier and Subwoofer Question.
Hey guys, just have a quick question on wiring a possible new setup I plan on getting. Well I have two Rockford Fosgate HX2 12" dual voicecoil 4ohm subwoofers, I currently power them with a RF P5002 subwoofer. I plan on picking up another P5002 amp. Now, my question is, after I get my next amp, to have a total of two amps, what is the best way to wire the amps to the subwoofers? The plan for me so far is to power each sub with their own amp. Hopefully someone can help me out, on the wiring. Thanks guys, sorry if I'm asking a dumb question, but I always wanted to power each sub with as much as my wallet can afford :-p.
Old May 16, 2007 | 06:44 PM
Nic@CiNcity's Avatar
Nic@CiNcity
That's how i'd do it too. Sounds right? I'm no car stereo super stunna though. I just fix/upgrade planes.
Old May 16, 2007 | 06:54 PM
doskiez's Avatar
doskiez
You can do amp to each or amp to both. I had one amp for 2 subs on my truck and it worked fine.
Old May 16, 2007 | 07:48 PM
snair2's Avatar
snair2
Well, what I wanted to really know, is the optimal wiring I should follow for one two channel amp powering one dvc 4ohm subwoofer. Should I hook up each coil to their own channel on the amp? Or should I bridge the channels on the amp then do whatever else on the sub connections?
Old May 17, 2007 | 04:44 AM
StreetOC192's Avatar
StreetOC192
P5002 Amp Specs:
125 W x 2 @ 4 Ohms RMS
250 W x 2 @ 2 Ohms RMS
500 W x 1 @ 4 Ohms Bridged RMS
HX2 12" RFR3112 Sub Specs:
Dual 2 ohm voice coil
RMS power 1000 watts
MAX power 2000 watts
I would bridge the amps to 500 watts to each sub wired in series to 4 ohms. It would be underpowering the subs a bit, but it would be your best option.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
