AMP. location
Old May 19, 2007 | 07:45 AM
ZuperVinn's Avatar
ZuperVinn
Default AMP. location
hey, can i get some ideas on where i can place my amp? right now its placed under my passenger seat. And it look like shiett..... pictures would be lovely =) My sub setup is under the swaybar. I built it with a friend for like 30 bucks compare to the 1 on ebay for about 200 bucks lol. well anyways if u guys have any ideas please share =) thanksss
Old May 19, 2007 | 08:28 AM
VoKaL's Avatar
VoKaL
That Amp Must Get Hot Under The Seats?
Why Not Get An Amp Rack From Zenclousres If They Sell Those Seperately...
ROSELL0522's Avatar
ROSELL0522
Put up a picture of what your box/trunk looks like and I could help. Also do you have the bose ten in it also? If not that's where we install a lot of amps for Z's inside that hole hidden.
Old May 19, 2007 | 08:32 AM
ZuperVinn's Avatar
ZuperVinn
noo i dont have bose and im glad lol. because i heard u have to rewire everything.
Where is it exactly? do u have any pictures?
this is how my box look like
Old May 19, 2007 | 08:39 AM
UHATEIT's Avatar
UHATEIT
as the previous person said about the bose 10 sub behind the driver seat.
i don't have the Bose sub so behind that is an empty compartment so i mounted a piece of wood and put my amp and distribution blocks behind there so it isn't seen.
***stupid cardomain isn't working right now or i would post the picture of what mine looks like. But its pretty easy to imagine
Old May 19, 2007 | 08:40 AM
ROSELL0522's Avatar
ROSELL0522
The bose aren't as bad as people make them sound. I took the bose system and added two 12" JL DVC W6's to mine with a 1500 watt pure digital kicker amp with custom made fiberglass box on top of the bose system's ten and mid's/high's. The key is to use a JL clean sweep. The bose ten is behind the driver's seat if you have it. My 12's point up at the hatchback lid for better sound and my amp is on an amp board under the sway bar lit up. I would of installed it where the ten is but it sounded good enough after the clean sweep was installed so I left it. Otherwise the amp would have been installed in there.
Old May 19, 2007 | 08:44 AM
ROSELL0522's Avatar
ROSELL0522
I'll try to get pictures loaded up. Do you want to keep your spare tire and jack in the car. I have roadside asst. so mine is covered. If you don't want them in the car then pull up the carpet in the trunk and an amp board can be made for in the dip, if done nice it looks great. You could light it up to show it even if you want then. Then cover with clear plexiglass and still use the trunk.
Old May 19, 2007 | 08:56 AM
ZuperVinn's Avatar
ZuperVinn
oh man good idea. i will look back there to see what i can do =).
any 1 here have instruction of how to take out all those plastic cover behind the seats so i can hide the wires and amp etc. It would save a lot of times with instruction =) thanks again
Old May 19, 2007 | 08:59 AM
ROSELL0522's Avatar
ROSELL0522
How do you get a picture from my file onto here? Sorry never done it before.
Old May 19, 2007 | 09:03 AM
cz3ch's Avatar
cz3ch
How do you get a picture from your file onto here? Sorry never done it before.
depending on the size of the amp mount it in the trunk area.. if it's a small mono block class d or something you can tuck it away in the foam cubbys somewhere.. you can also build a facade to cover up the back area and mount it for display..
Old May 19, 2007 | 09:14 AM
ZuperVinn's Avatar
ZuperVinn
i have no idea. go to www.photobucket.com and sign up for the thing. its free and it comes in handy
Old May 19, 2007 | 09:15 AM
ZuperVinn's Avatar
ZuperVinn
naw my amp is pretty big =) any pictures?
Old May 19, 2007 | 09:31 AM
ROSELL0522's Avatar
ROSELL0522
http://s187.photobucket.com/albums/x...peakers002.jpg
SORRY this is the only way I could figure it out. Not the best pictures but you get the point.
Old May 19, 2007 | 09:47 AM
ZuperVinn's Avatar
ZuperVinn
not my cup of tea. doesn't look too showy if u know what i mean. But that is definitely a good setup if i dont want any trunk space. thanks for the pic
Old May 19, 2007 | 11:47 PM
DJMatrix1067's Avatar
DJMatrix1067
As for how to remove those plastic covers to hide the amps (the one where the factory bose 10 goes)...
1. Take a flat bladed screw driver, and carefully wrap the blade with a piece of electrical tape. Be sure it covers all the metal (this will protect the plastic)
2. Find the seam where the plastic cover meets the surrounding. Insert flate blade in between, and it should pop out.
On another note, I'm gonna put my amps in there too. Has anyone had problems with heat in there?
Old May 20, 2007 | 03:58 AM
Lsmith9523's Avatar
Lsmith9523
Try doing a search,,,,there are threads here that describe, step-by-step, how to take the inside of the car apart. I used these threads to install my complete stereo set-up. Lots of great, helpful info.
Old May 20, 2007 | 06:55 AM
Kwame's Avatar
Kwame
I mount 2 of my amps here...
Old May 20, 2007 | 07:29 AM
DVFlyer's Avatar
DVFlyer
Speed of White
I have a few things in the cubby behind the driver's seat.
Old May 20, 2007 | 07:40 AM
Mike Wazowski's Avatar
Mike Wazowski
put mine in the glove box
Old May 20, 2007 | 08:16 AM
UHATEIT's Avatar
UHATEIT
finally got my pictures to work on cardomain, here you go, EASY to do, good luck! Doesnt have to be super clean... no one looks behind the seats anyways!
