need help!
Old May 23, 2007 | 03:51 PM
imsonastie's Avatar
imsonastie
Default need help!
the nissan dealership is giving me the run around on how to fix the problem, so im pretty pissed right now, anyway my keyless entry for my car went dead, so i replaced the battery and and it still wont let me start the car, is there some sort of program i have to do?
Old May 23, 2007 | 03:54 PM
Ichigo's Avatar
Ichigo
? Nissan doesn't make a remote start. Four buttons on your remote.
lock
unlock
trunk release
Panic
If you mean that the keyfob wont do anything.. you do have to program it
Old May 23, 2007 | 03:58 PM
imsonastie's Avatar
imsonastie
i replaced the batery in the remote man. thats whats not working, and my alarm is on from when i closed the doors this morning, so the alarm wont let me start the car.
Old May 23, 2007 | 04:17 PM
Spike100's Avatar
Spike100
As Ichigo points out, your FOB now requires reprogramming.
--Spike
Old May 23, 2007 | 06:39 PM
Ichigo's Avatar
Ichigo
Its all good man, here you go:
Originally Posted by Everybodywildou
...from a website online
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your car , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consistent pace. (97 and earlier are fast) When you see the hazard lights flash, put key in ignition switch and turn to the On position .. Do NOT CRANK or you will have to Start over .. After in the On position .. Hit the Lock button on remote... Hazard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn ignition switch off and unlock door and get out and try it. If you are doing more than one. While still in Vehicle with Key on . After you hit the Lock button on Remote and hazard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try. Good Luck
