CD in disconnected HU
Old Jun 5, 2007 | 01:24 PM
edchoy02's Avatar
edchoy02
Default CD in disconnected HU
Had a Kenwood DNX7100 NAVI installed yesterday and totally forgot that I had a cd in the stock 07 Bose HU until today.
Does any one know how to take a CD out of a HU that has been disconnected (no power)?
Old Jun 10, 2007 | 12:04 AM
lbz's Avatar
lbz
I'm not sure if this procedure will work because the clamping mechanism that holds the CD in place while it spins during playback may need to be released. I'm not sure if this release happens when power is turned off or if it happens only when the eject button is pushed. However, I was able to open up the HU fairly easily without breaking anything.
Remove the small phillips head screw at the rear edge of the top cover and use a small flathead screwdriver to carefully pry the metal fasteners for the top cover plate loose. Working from rear edge pry the top meal cover off the HU which will expose the CD drive mechanism.
There's a white plastic arm near the center of the back edge. This is the normal eject mechanism. If you move the end of it toward the front of the HU, it will push against the edge of the CD and the CD will come out of the slot just enough to get a grip on it IF the clamping mechanism is already released.
If the CD won't move, that means the clamp is still down and you will have to find a way to release it.
After the CD is out, snap the top cover in place, push the fasteners back into place as needed and put the screw back in.
The other option would be to take it to a Best Buy (or other) car audio installation center / shop and ask them to use their bench power supply to apply power and hit the eject button. They should be able to determine the pin outs for the power and ground connections by looking at a Nissan wiring harness adapter which most places should have in stock. If you get there early when they first open and are not busy, they might do it for free or at worst charge you $25 or so.
Old Jun 13, 2007 | 02:09 PM
edchoy02's Avatar
edchoy02
Thanks I'll give it a try tonight.
Old Jun 13, 2007 | 04:04 PM
BlueBoxer's Avatar
BlueBoxer
Yup, most stereo shops will just power it up and eject it for you. Safest option IMO.
Old Jun 13, 2007 | 04:07 PM
QuicksilverZ33's Avatar
QuicksilverZ33
this might be usefull to you....
https://my350z.com/forum/showthread.php?t=274698
Old Jun 13, 2007 | 08:59 PM
lbz's Avatar
lbz
Cool find!
I agree on the safest option being the shop approach. I would recommend strongly against messing with it if the CD is clamped down. VERY easy to break stuff in there.
I put a CD in without it being powered up just to see what would be involved...
Old Jun 13, 2007 | 09:13 PM
John Bronze's Avatar
John Bronze
hook it up to a battery and eject it
Old Jun 16, 2007 | 01:02 PM
QuicksilverZ33
Originally Posted by lbz
Cool find!
Im the one selling it lol
Old Jun 18, 2007 | 11:05 AM
Apanther's Avatar
Apanther
+1
Old Jul 7, 2007 | 07:47 PM
roast's Avatar
roast
Well i took my stock head unit apart just for ****s and giggles.... a jammed cd is not as easy as just pulling that white lever.... i tried a few things and eventually said to hell with it....and took it apart piece by piece...and no way im going to try to put it back together....
Siqcology
Sep 18, 2019 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Beater350z
Sep 9, 2015 03:36 PM
Bruce Brettschneider
Nov 22, 2005 04:23 AM
momentum
Nov 29, 2003 07:42 PM
