Where to run 0ga wire through firewall
Old Jun 6, 2007 | 08:37 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Default Where to run 0ga wire through firewall
Hi all,
I will be running the 0ga wire for my audio upgrade this weekend (hopefully). I will be running two 0ga wires. I ordered firewall bushings to facilitate this.
Has anyone run 0ga wire through the firewall (or anywhere for that matter) *cough* bing *cough* who could give me an idea of where they put it?
Thanks.
Old Jun 6, 2007 | 10:01 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
I did, through to passenger side firewall then along the pass floor all the way to the glove box area. I ran my rca and front comp wires through the center to avoid any additional noise(whining) worked like a charm. I cant remember but i think it would be a bietch to run 2 of them though.
Old Jun 6, 2007 | 10:28 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks..... The 4ga for my current system is run that way so I'll be basically following the same path, but it goes through an existing rubber boot where the 0ga won't fit..... Time to drill holes.
I know one person who ran wires under a car through channels, but that was not a Z.
Old Jun 6, 2007 | 10:48 AM
ARMSTRONGARMS
my 0ga went through the factory boot? inside the battery compartment.
Old Jun 6, 2007 | 10:51 AM
ARMSTRONGARMS
https://my350z.com/forum/showthread....threadid=26618
Old Jun 6, 2007 | 11:04 AM
DVFlyer's Avatar
DVFlyer
Speed of White
GREAT news! I just assumed the 0ga wouldn't fit.
Great link too. Thanks.
Old Jun 6, 2007 | 11:11 AM
VO...'s Avatar
VO...
Administrator
+1. Look at the picture I've attached. The boot is to the right of the screw driver behind the fuse box that is mounted on the fire. There's a large bundle of wires going into it. Make a small slit in the boot with a razor, take you cable and rub some soap on it, then feed it through the boot. It'll pop out over by the kick panel under the dash. The soap will make it easy to feed through the boot. It's a b!tch trying to dry feed it. Seal the boot up with silicone after you're done.
Old Jun 6, 2007 | 11:18 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks. There is a picture in the linked thread above that shows exactly what you're talking about. Getting giddy with excitement about adding all this "powa".
Old Jun 6, 2007 | 11:22 AM
savvy's Avatar
savvy
my 0ga does through the battery also.
Old Jun 6, 2007 | 12:22 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
+ 245 amps of current?
Dang do you have a dual alternator set-up (pictures please!).
Old Jun 6, 2007 | 02:11 PM
ARMSTRONGARMS
no prob
Old Jun 8, 2007 | 10:11 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Started running wires tonight: 2 runs of 0ga
Attached Thumbnails Where to run 0ga wire through firewall-0ga-into-wire-boot.jpg
Old Jun 9, 2007 | 08:36 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
now how are you gonna run TWO 0 guages that the amps want mike?
b
Old Jun 9, 2007 | 12:21 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Already run. I was able to run both down the passenger side of the door. Two were a bit too big to fit under the carpet, but one of them was able to be pushed through the white plastic piece directly to the right of the seat and then they BOTH fit into the white plastic channel further back. So not only do they both fit now, but I can also fit the three runs of 14ga Tsunami speaker wire.
Not bad if I do say so myself.
Old Nov 7, 2008 | 09:47 PM
damoniusmonk's Avatar
damoniusmonk
Will your system suffer from hum with that setup? I was wondering because the speaker wires are so close to the power wires.
Or is it only a problem if you run RCA wires next to power wires??
Old Nov 7, 2008 | 10:11 PM
ARMSTRONGARMS
I dont run any other wires next to the power wire i would run the speaker and rca's down the center or down the driver side to avoid any noise.
Old Nov 13, 2008 | 10:44 AM
burner's Avatar
burner
Damn man what kind of amps are you running that you need 0ga wiring?
Old Nov 13, 2008 | 02:01 PM
folgrz's Avatar
folgrz
old thread but he was running 4 DLS Ultimate amplifiers if i am not mistaken
Old Nov 13, 2008 | 02:59 PM
DVFlyer's Avatar
DVFlyer
Speed of White
for bringing up old threads.
No noise in my system. The general rule is to keep signal wires (RCA's) away from power wires. But if you can separate them all, even better I guess.
Yes, folgrz is correct, I had 4 DLS amps (approx 1800 watts).
Sadly all gone, though....
Old Nov 13, 2008 | 05:56 PM
orgasm_donor's Avatar
orgasm_donor
You can run speaker wires with any other wires. High level information will not induce noise.
