10" bazooka tube, is it possible?
Old Jun 19, 2007 | 01:27 PM
JetBlack3's Avatar
JetBlack3
Default 10" bazooka tube, is it possible?
I really want to utilize the stock sub location and I have a JL 10w3v2 left over from my old car's system. It's gonna sound like sh*t if I just put it straight in without a box, but I don't want to go through the hassle of constructing a box in that tiny little space either. Is it possible to fit a 10" bazooka tube in there? I searched and found that an 8"er will fit, but that's weak. Anyone know if I can fit it in there with or without modification?
Old Jun 19, 2007 | 01:33 PM
DVFlyer's Avatar
DVFlyer
Speed of White
What is the length of the tube? If it fits, it will be firing sideways which I don't think would sound good. You'd be better off laying the tube down in your hatch area.
Old Jun 19, 2007 | 01:38 PM
JetBlack3's Avatar
JetBlack3
Yeah see that's what I was trying to avoid. This is my only car, and the "trunk" space is small enough as it is, so I really wanted to get the sub behind the seat. What I was thinking of was having the sub still fire forwards towards the seat, and modding the tube so it fits behind the sub. You're right, it probably would sound terrible if I just threw the tube into that little compartment.
Old Jun 19, 2007 | 02:33 PM
JCZ33's Avatar
JCZ33
The 8" tube would be nice, and could fit under the strut bridge; just replace the sub with something stronger.
Honestly I like the little BOX that fits in the left corner, holds a 10" I think; not sure who makes it.
HERE...
http://cgi.ebay.com/ebaymotors/350z-...em290111704915
I like where the other subs are in the hatch, recessed under the strut brace..
Old Jun 20, 2007 | 03:43 AM
Lsmith9523's Avatar
Lsmith9523
HERE...
That is the corner box from Zenclosures. Google zenclosures and check them out. Mike is a super guy and might have something that will work for you.
Old Jun 20, 2007 | 07:18 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Or have someone custom make one for you..... This is mine.
Old Jun 21, 2007 | 10:12 AM
maxipad96's Avatar
maxipad96
I had an 8" tube in my old Z. Fit perfectly and fired in whatever direction I wanted it to. I assume the 10" wouldn't be that much larger. My 8 fit fine wrapped with a lot of carpet padding to reduce vibration and hold it in place.
Old Jun 21, 2007 | 01:57 PM
JetBlack3's Avatar
JetBlack3
that custom one is legit
Old Jun 25, 2007 | 07:53 AM
SIRSHREDSALOT's Avatar
SIRSHREDSALOT
hey maxi, how did the 8 inch tube sound ???? I assume you had it in the stock sub compartment ?
Old Jun 25, 2007 | 12:37 PM
maxipad96's Avatar
maxipad96
It sounded pretty good. No rattles, added a little bit of bass but by no means any "thump". Could hear/feel it well from both seat locations. Sounded basically stock from outside though. I think I bought mine for like 100 bucks. Was well worth the 100.
Old Jun 25, 2007 | 09:42 PM
WhiteZed's Avatar
WhiteZed
i had an 8" bazooka in the stock cubby
before i actually decided on a system,
and it sounded good, wasnt head blowing, but definatly decent
sounded better in the trunk, but you dont want it in the trunk cause it will be ugly!
i am pretty sure you could fit a 10" and all you would need to do it grind away the metal lip that the stock sub bracket bolts on,
i was going to do this, but couldnt be bothered.
i used a stack of cotton felt to hold it in place,
it never moved after about 6 months.
10" would be better if you feel like grinding metal everywhere...
maybe some super heavy duty metal snippers would cut thru it, and make no mess.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
350Shadow
Sep 22, 2015 08:30 AM
juang20
Intake
Sep 7, 2015 05:37 PM
