RCA cables with ground wires
Old Jun 25, 2007 | 10:51 AM
Hybrid90's Avatar
Hybrid90
Default RCA cables with ground wires
I'm using MOnster interconnect cables with the lil strand of ground wire coming out of it. My question is.. do I just twist it all together and ground it? Also can I do the same for the amp side.. twist the ground cables together and just tap it into the grounding tab of the amp? Or can I just leave the grounding wires alone?
Old Jun 25, 2007 | 10:53 AM
sam30540's Avatar
sam30540
i believe i have heard that the wire in the middle is for you amp turn on that comes out of your radio.
Old Jun 25, 2007 | 11:06 AM
Hybrid90's Avatar
Hybrid90
No no, I'm not talking about that wire.. I'm talking about a bare metal wire that comes out the side of each of the rca head. It's kinda like how some aftermarket sparkplug wires have the bare ground wire coming out of it...
Old Jun 25, 2007 | 11:16 AM
VO...'s Avatar
VO...
Administrator
I've never heard of this. Please post pics so we can evaluate.
Old Jun 25, 2007 | 11:44 AM
StreetOC192's Avatar
StreetOC192
The bare copper wire coming out of the rca plug is indeed a drain wire that you will ground on the HEADUNIT SIDE ONLY! grounding both sides can/will cause a ground loop and introduce noise into the signal instead or draining away from the amplifier.
Old Jun 25, 2007 | 01:21 PM
Hybrid90's Avatar
Hybrid90
The rca is not coming from the HU.. it's coming from sound processor going to the amp.. so can I just connect those bare wire to the negative wire of the processor unit?
Oh and I can't seem to find any pics of the rca I'm talking about.. sorry
Old Jun 25, 2007 | 01:38 PM
StreetOC192
Correct, I guess I should have said to ground the wire to the chassis on the SOURCE side of the RCA cable(s) meaning headunit, EQ, processor, etc.
Old Jun 25, 2007 | 01:42 PM
Hybrid90's Avatar
Hybrid90
Thanks!
Old Jun 25, 2007 | 02:03 PM
ZSpectrum's Avatar
ZSpectrum
The wire in the middle is not a ground but a signal on lead. You connect it to the remote input on your amps. My knu konceptz wiring had it.
Old Jun 25, 2007 | 02:31 PM
Hybrid90's Avatar
Hybrid90
Not the same wire we're talking about.. I know that wire. This one is a brass/gold bare wire.. thanks.. got the answer I was looking for
350Z_Al
Oct 29, 2020 07:44 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
