Component Suggestions...
Old Aug 11, 2007 | 06:18 AM
Zulu-6's Avatar
Zulu-6
Default Component Suggestions...
I'm currently looking at component setups for under $300 to replace my Infinity Reference coaxial. My local dealer has recommend JL VR650, one reason being the tweeters will fit in the factory locations.
I know there are quite a few knowledgeable car audio people here so I would like some suggestions from you.
Thanks
Edit: Reason I am wanting to replace the Infinities is ever since I've amped them the highs have a "shrill" to them when played at higher levels.
Old Aug 12, 2007 | 10:05 AM
Tackett's Avatar
Tackett
CDT audio FTW
you can get some HD series for about 300 bucks. will blow anything else out of the water in that price range.
http://www.woofersetc.com/index.cfm?...roduct_ID=5091
wham. great componets at a great price.
Power Handling: 150 Watts RMS
Frequency Response: 55-20kHz
Sensitivity: 92.0 dB
find other componets at that price with those numbers. Just get a nice clean amp to push them and you will be amazed.
Old Aug 12, 2007 | 01:28 PM
dkmesa350z's Avatar
dkmesa350z
CDT has some great choices. I also like Boston Pro60s, JL XRs, and my current set Rainbow SLC265 - http://car.rainbow-audio.de/products...n=7&art=231150 a wonderful set of comps. Let me know if you are interested and I will refer you to an authorized retailer that sells them for $225 shipped (where I got mine)
Old Aug 12, 2007 | 08:39 PM
Tackett's Avatar
Tackett
I have not heard the rainbows personally, and as such, cannot vouch for them. But I can say I have heard EVERYONE say that they kick freakin ***. Ive not heard a single bad comment on them. As for JL, I have heard every single model available and I dont like them. In my opinion, they just dont have enough treble to them, and when you get the high frequencies up to snuff, they shut off from overload. However, this is only my opinion and you know what they say about that
Old Aug 12, 2007 | 11:44 PM
Zulu-6's Avatar
Zulu-6
Would you say you like your high's "bright" then? For example, with my home audio setup I like more of a warm sound, don't really care for the horn tweeters that are in Klipsch which come off as "bright.
Zulu-6's Avatar
Zulu-6
Thanks for the recommendation! What kind of tweeter do they come with?
Old Aug 12, 2007 | 11:54 PM
Zulu-6's Avatar
Zulu-6
...and will these fit in the stock locations?
Old Aug 13, 2007 | 05:05 AM
StreetOC192's Avatar
StreetOC192
I really love my Diamond D661 components. The can be purchased with either a silk tweeter (warmer), or an aluminum tweeter (brighter) depending on your tastes. I really like the punchiness of the aluminum woofer. They can be purchsed for $200: http://www.woofersetc.com/index.cfm?...roduct_ID=2715
If you can extend your budget to $330, you can get their HEX series components, also with either silk or aluminum tweeters: http://www.woofersetc.com/index.cfm?...roduct_ID=1138
However, asking for component recommendations is like asking for underwear recommendations......you won't know what YOU like until you try them on.
Old Aug 13, 2007 | 05:08 AM
StreetOC192
Almost any component woofer will require a spacer to fit in the stock location. I think there might be a DIY on how to use the stock speaker bracket as a spacer...
Very few tweeters will fit in the sail panels in the stock location, but you can modify the sail panel to accommodate an after market tweeter......or you can relocate them to another location that might suit your listening tastes better.
Old Aug 13, 2007 | 05:18 AM
Zulu-6's Avatar
Zulu-6
Thanks, I appreciate the info.
Yeah, I know speakers are a very subjective choice, I just don't have many options to listen to a variety of speakers in a small town.
Old Aug 13, 2007 | 05:21 AM
Zulu-6's Avatar
Zulu-6
Is it possible to do this with the tweeter that come with the D661s?
Old Aug 13, 2007 | 05:29 AM
StreetOC192
I didn't try to fit the tweets in the sail panels because I am using the Zenclosures door pods and the tweeter mounts in the pod.....If I had to venture a guess, I would say no only because you would need to make a custom bracket or maybe take the tweeter out of its plastic housing to get it to fit. It probably wouldn't be a direct drop-in replacement.
You could however remove the factory tweet and bracket, cut a hole in the plastic sail panel and use the flush mount cups to mount the tweets there....it just won't "look" stock.
Old Aug 13, 2007 | 08:47 AM
james840a's Avatar
james840a
I went from Infinity Reference components to Focal 3-ways and what an amazing differance in sound. My 3-way is mounted down in the kicks and door. My tweeter is not mounted in the sail anymore. Keep your tweeter close to the mid range speaker as possible. Having them mounted were factory is would not be the best.
Old Aug 13, 2007 | 07:53 PM
Zulu-6's Avatar
Zulu-6
Thanks for all the recommendations but it all came down to what I could actually test with my own ears and today I went ahead with the JL VR650csi, they beat out everything else I was able to demo.
I will keep the Rainbows, CDT and Diamond in mind for future projects.
Old Aug 14, 2007 | 04:41 AM
350zspl's Avatar
350zspl
CDT
Rainbow
Hertz
Morel
DYNAUDIO
DLS
OZ Matrix
Id Max
all great comps
Old Aug 14, 2007 | 04:50 AM
blasian's Avatar
blasian
I'm enjoying my DLS UP6 components
Old Aug 14, 2007 | 07:38 AM
james840a's Avatar
james840a
Originally Posted by 350zspl
CDT
Rainbow
Hertz
Morel
DYNAUDIO
DLS
OZ Matrix
Id Max
all great comps
Dont forget Focal
Old Aug 14, 2007 | 07:42 AM
Tackett's Avatar
Tackett
hey man just a wee bit of advice...dont put those tweeters in the stock location. If you hate bright highs, it will be ear peircing. The best place for them is in the kick panels. (where the fuse box is located. same on passenger side.) Measure and drill out two holes in the same spot and mount them there. you will get a much warmer sound.
Old Aug 14, 2007 | 08:02 AM
jadaniya's Avatar
jadaniya
Hey. I will offer my bit of input since I have been really into car audio in the past and some of my friends are really into them currently. I have heard the top of the line JL's (which of a friend of mine has paid $1,000 a pair for the front pair and $800 a pair for the back pair) and they are really good. If you amp them they are really LOUD and clear even from a far distance. You can hear him coming from far away. I'll put that out as a standard point as you can tell JL puts out good products, but in your price range it will obviously not be as good as a $1,000 pair of speakers. One of my other friends has a Boston acoustics (~$400 a pair) set up and they don't sound as good to me, but get fairly loud (not as loud as the JLs) and the highs are really ear piercing if brought up to a loud volume, while the JL's are more balanced. One of my friends also has a set of focals in his mr2. They are moderately amped and don't get as loud as the other two (mentioned above), but are really bright and sound amazing. So far, JL top of the line = too much $ to even consider, focals > boston. the bottom line focals ran my friend about $250 for a pair. they are in your price range and sound pretty damn good. I personally have a set of diamond D6s and think they sound great. They are currently amped to an mtx 4 way amp pushing about 75 watts rms to each speaker. they get loud enough in the car where you could push them further (but maybe too loud for in the car), but not that loud out of the car. they sound great and if I had to decide between the diamond D6's and the focals I'd just pick which ever one was cheaper b/c they are both good enough for me. I hope that helps you atleast a little. Brands that I haven't heard personally I suspect would be good are Image Dynamics and rainbows.
Old Aug 14, 2007 | 08:31 AM
dkmesa350z's Avatar
dkmesa350z
Here is my install thread. They fit with some simple angled spacers and the tweets sit nicely in the sail panel
http://www.caraudio.com/forum/showthread.php?t=227702
