Help!!!!!
Old Aug 14, 2007 | 07:58 AM
white07z's Avatar
white07z
Default Help!!!!!
Does anybody know how to install a converter on the stock head unit, i am adding subs and an amp, but i need to know where to put the wires of the converter, im using a db link converter. anything would help i need to know asap b/c my car is apart right now~~~~
Old Aug 14, 2007 | 08:03 AM
SuperBlack350z's Avatar
SuperBlack350z
if you are talking about the rca inputs, then you would tap it in one of the stock speaker wires.
Old Aug 14, 2007 | 08:04 AM
motorheadrr's Avatar
motorheadrr
are you hooking up an RCA converter?
Old Aug 14, 2007 | 08:10 AM
white07z's Avatar
white07z
yes its the rca inputs
Old Aug 14, 2007 | 08:11 AM
white07z's Avatar
white07z
which ones r the stock speaker wires do colors please
Old Aug 14, 2007 | 08:15 AM
SuperBlack350z
well just take off some of the rear trim panels to access the back of the speakers to clearly see the positive+ and negative- wires. Then tap yours into that.
Just remember you won't get perfect sound quality with rca inputs.
Old Aug 14, 2007 | 08:44 AM
Tackett's Avatar
Tackett
the converter should have a wiring guide...
if you look really really closely at the harness wires, they will say "right rear speaker" "right front speaker" and so forth.
Old Aug 14, 2007 | 08:55 AM
white07z's Avatar
white07z
thank you very much guys!!!!! greatly thankful for ur input and help, now i can continure working, thnks!!!!!
Old Aug 14, 2007 | 08:58 AM
white07z's Avatar
white07z
One more thing what about the remote cable what fuse can i tap into that would be best
