pioneer head unit and bad stereo reception
Old May 14, 2003 | 04:37 AM
Quick's Avatar
Quick
Default pioneer head unit and bad stereo reception
okay, i just installed (or this weekend at least) a new pioneer AVHP6400DVD player. It works great except for the stereo reception. It keeps fading in and out. This didn't happen with either of the previous 2 stereos i had (the stock, and an alpine). Any ideas on how to solve it?
Old May 14, 2003 | 04:59 AM
noahbuddy's Avatar
noahbuddy
make sure the anntena power-lead is still connected. maybe the conversion plug you are using doesn't have that lead?
Old May 14, 2003 | 07:01 AM
mf01's Avatar
mf01
I am having the same problems with my rockford fosgate deck, whereas I didn't with this deck in my old car.
I don't have the antenna lead connected. Is it some type of amplified antenna? I don't see why it needs to be connected. I mean usually it is for a power antenna.
Old May 14, 2003 | 12:54 PM
Quick's Avatar
Quick
yea, i don't have it conected either. I didn't realize it was power.
My new head doesn't have a power a lead. Should i connect it to to 12v ign wire or the remote turn on wire?
Old May 14, 2003 | 10:06 PM
jeffa's Avatar
jeffa
Connect it to the amp remote turn on wire from the Pioneer unit. The antenna in the Z is amplified, and you will get crappy reception without sending power to this wire. It is referred to as the amp turn on wire in most wire diagrams I have seen on the Z. I can't remember what color the wire is in the factory harness that I connected to.
Old May 15, 2003 | 05:07 AM
Quick's Avatar
Quick
Okay, hooked it up last night.... much better now!!!
Old May 15, 2003 | 06:58 AM
zaway's Avatar
zaway
You guys rule, I've had this problem for a few weeks now.
Quick, which wires did you connect?
zaway
Old May 15, 2003 | 08:00 AM
Quick's Avatar
Quick
I hooked the remote turn on lead for the head unit to the power antenna wire on the metra harness. Works perfectly now!
Old May 15, 2003 | 02:47 PM
MonkeyBoy's Avatar
MonkeyBoy
For those of you who are not using a harness and just crimping wires, on the stock stereo plug, it is the green/white striped wire that is the power to the antenna. Connect this to either your antenna power lead from your head unit or the remote amp turn on wire. Either will work.
Old May 15, 2003 | 04:18 PM
jeffa's Avatar
jeffa
You should NEVER cut off the factory radio harness connector! This will be a warranty issue down the road...
You should always use a wire harness adapter. It's easy to prewire, and it allows you to reinstall the factory radio when you sell the car.
Old May 16, 2003 | 12:07 PM
MonkeyBoy's Avatar
MonkeyBoy
There will only be a warranty issue if the stereo caused some sort of problem. Which I do not see happening. Unless of course you feel that the actual new headunit would be covered under warranty, and then maybe I can get it replaced if lightning struck my car ...
Otherwise, I honestly believe a dealer would be hard pressed to think that having factory wiring going into a headunit sans "connector" would cause a problem. Especially since an argument can be made that a "connector" and individual crimping is essentially the same thing, minus the $29.95 metra harness part. And if they did, sure as hell would have a huge lawsuit on their hands.
It is good to give people warnings in regards to mucking around with existing electrical systems in their car, but if those people know what they are doing, your response can be considered rude, not to mention inflammatory. A blatant statement of a warranty void is what makes several people not want to enjoy the potential of putting a new stereo in, or anything else for that matter.
Now for all the people who do NOT know what they are doing, yes, get the harness or have a trained professional stereo installer do the work for you. Oh and I can guarantee that 8/10 times (depending on the car mind you) a harness is NOT used at stereo installer shops.
Old May 16, 2003 | 02:45 PM
jeffa's Avatar
jeffa
My post was not ment to be rude or inflamitory. If you took it that way, I'm sorry, but I still stand by my statement.
I've been in the industry for many years. Most shops use harnesses. It's easier to install a unit when you don't have to cut and splice into the factory harness, and dealers do not want to even approach a warranty issue by not using an aftermarket harness adaptor with the factory plugs. Trust me, I've been there...$9.95 for a Metra harness is cheap insurance, not to mention the ease of install.
And, a lot of dealers have a service where they will remove your aftermarket equipment that they sold to you when you sell your car as part of the original labor charge to install the system. Guess why they would not cut off the factory harness plug?
Old May 17, 2003 | 12:02 PM
zaway's Avatar
zaway
just connected the antenna wires and radio reception is back
Thanks for the help.
zaway
Old May 22, 2003 | 11:02 AM
dbaker910's Avatar
dbaker910
Thumbs up Bad Reception with Alpine HU
You guys are the best.......I had the same problems with my new Alpine HU. I didn't think that the antenna was powered. Thanks for the help!
Old Nov 7, 2005 | 03:05 PM
boma's Avatar
boma
Thanks ! I just used this and it worked !!!
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
kyin
Oct 15, 2015 05:54 AM
