Wiring Help
Old Aug 16, 2007 | 11:52 AM
hotsonhk's Avatar
hotsonhk
Default Wiring Help
I have the Alpine CDA-9885 headunit, polk db6501 components, and an mtx thunder 7402 amp. I need a advice with the correct way to wire all of this up correctly. I installed the deck with the metra kit and it looks very nice, flush.
Which outputs on the deck do I use for the front? The rears? (I am leaving the stock rears in for now.)
Where should I mount the amp? It wont fit in the passenger cubby, but it will fit in the driver side cubby if I remove the bose plate. Is this a good mounting area? If so, how do I get that plate off?
Thanks in advance guys.
Old Aug 16, 2007 | 12:04 PM
Takhteh's Avatar
Takhteh
maybe two threads down from yours..
https://my350z.com/forum/audio-and-video/294464-subwoofer-bracket-behind-drivers-seat.html
the Driver's side is great for housing amps, just make sure you leave some room on the sides or wherever the amp vents are located so that you don't suffocate the damn thing (it can get hot back there depending on your location)
Old Aug 17, 2007 | 02:24 AM
hotsonhk's Avatar
hotsonhk
Thanks for the response Takhteh! That plate was a real pain to get off, at least 14 bolts under all that plastic, never again. All the wiring wasn't too fun either, especially workin in the las vegas heat at 105. Lost some weight today.
I got everything in though, and it sounds great! But I will definitely been needing some subs. I'm thinkin the Zenclosures box and 2 mtx's 10's.
Old Aug 17, 2007 | 09:42 AM
Takhteh's Avatar
Takhteh
Lost weight, haha.. Yeah, I just got the Zenclosures, too. You will not be disappointed with the 2x10s!
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
