Rear speakers cutting out???
on
I have an '05 with the Bose system.... I upgraded my headunit about a year ago but have been running stock speakers. When I had the stock bose headunit in there occasionally when making a turn or hitting brakes the rear speakers would cut out.... this stopped once I changed for an aftermarket receiver... however now all of a sudden the speakers have started to cut out from time to time again (rears only)... any ideas other than 'check your connections'?
Living in 350Z
Start in the dash.
Typically there is a plug for the power, ground, etc., another for the front speaker pair, and another for the rear speaker pair. Some times you'll have just a bundle of wires with all three together. If you're certain that both speakers are cutting out together that's where I'd look for the loose connection.
08-06-2021 06:19 AM
