New System Installed!!!
Old Oct 13, 2007 | 12:41 PM
dewoof01's Avatar
dewoof01
Default New System Installed!!!
Ok, so some of you may have seen my posts regarding my install. I just picked the car up last night and don't have pictures yet but will have them up by tonight for sure. The system is composed of pioneer D3 head unit, Focal 165A1 component set in the front doors tweets and mids all in factory locations, as well as 165ca1's in the rear stock speaker location. 2 jl 10w3v2's one behind each seat both inside full MDF box custom made and new custom panels made for each slot with JL grill covers. Also 2 JL 10w3v2's in hatch area in custom built box aimed at rear glass. New false floor installed in trunk area with amps mounted underneath plexiglass with led light shining on amps. The amps are a e1340 running the 6.5"s front and rear, and a E1800 at 2 ohm running the 4 JL subs in the car at 1000w RMS all together. Also a sub volume control installed in factory heated seats switch location, as well as a switch mounted in same location that switches between running the 2 subs behind the seats at 4ohms only and when switched the other way runs all 4 subs in car at 2 ohm, quite a difference! WIll post pics later.
Old Oct 13, 2007 | 02:03 PM
dewoof01's Avatar
dewoof01
sorry wrong pic I'll try again.
Old Oct 13, 2007 | 02:07 PM
dewoof01's Avatar
dewoof01
2 subs in rear in custom box with false floor and 2 amps under plexiglass.
Old Oct 13, 2007 | 02:08 PM
dewoof01's Avatar
dewoof01
Custom Sub enclosure behind seats with custom panels.
Old Oct 13, 2007 | 02:10 PM
dewoof01's Avatar
dewoof01
Sub Volume control as well as switch between 2 front subs only and all 4 subs.
Old Oct 13, 2007 | 02:11 PM
dewoof01's Avatar
dewoof01
rear hatch area with subs and factory rear mat cut out to fit.
Old Oct 13, 2007 | 02:13 PM
dewoof01's Avatar
dewoof01
Amps Under Plexi mounted on rack.
Old Oct 14, 2007 | 02:06 PM
hockiman90's Avatar
hockiman90
if you don't mind me askin where did you get the custom made box?
Old Oct 14, 2007 | 04:15 PM
dewoof01's Avatar
dewoof01
All the custom boxes and panels as well as false floor and amp mountings were made by Scooter at car toys in Beaverton, Oregon. Last year he was rated in the top ten car audio installers in the nation. He did a fantastic job, wasn't cheap, but you get what you pay for. All the wiring, head unit, and speakers I installed, and he cleaned up my install wiring. Each of the sub boxes behind the seats ran about $450-500 including the custom panels and grills as well. Looks stock.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
nanotech
Oct 2, 2015 05:02 AM
