JL 10W6v2 or Rockford T110
Old Nov 2, 2007 | 01:32 AM
kullnan's Avatar
kullnan
Default JL 10W6v2 or Rockford T110
hi guys, i bought the zenclosures box for 2 10' subs and am trying to figure out a good pair to put in there. so far i came down to these 2 subs. the JL 10W6v2 and the Rockford T110. i guess im asking for your guys opinions to help me decide which ones to go with. pros and cons would be nice
Old Nov 2, 2007 | 04:53 AM
350zspl's Avatar
350zspl
you got the box ?
for 2 each 10" ?
what is the mounting depth enclosure allows?
do you already have amp?
if yes on amp or no on amp, will you be using 1 or 2 amps to run the 2 subs?
what is the air space in box ?
i would recommend using a mono amp ,1 each ,to run the 2 subs,and the amp needs to be 1 ohm stable
i would get 2 each 10" DVC 4 ohms subs so they can see a final 1 ohm load
tell me mounting depth
air space
budget ?
kinda music you like
and than we can talk sub choice and amp
T1 sound like *** sealed
Old Nov 2, 2007 | 05:31 AM
The Closer's Avatar
The Closer
JL FTW! Just put two 10w3v3's in a Zenclosure. They sound great!
Old Nov 2, 2007 | 05:34 AM
michaeljr6's Avatar
michaeljr6
w6v2 > rf
image dynamic or FI >
Old Nov 2, 2007 | 06:22 AM
Lsmith9523's Avatar
Lsmith9523
Depending on how loud/what type of bass you are trying to achieve,,,you can use 1 mono amp,,,run 2 subs, wire subs to an 2ohm load,,,,make sure the amp is 2ohm stable,,,that will provide you with PLENTY of sound. And, less draw on the electrical system by only using one amp.
Old Nov 2, 2007 | 09:59 AM
The Closer's Avatar
The Closer
^^ Thats my configuration. Works great!
Old Nov 2, 2007 | 10:22 AM
SuperBlack350z's Avatar
SuperBlack350z
def get the T1 in this case. The t1 takes very little space for enclosure but sounds really loud and undistorted. I heard one and it's just as loud as my jl w7/
Old Nov 2, 2007 | 10:38 AM
350zspl's Avatar
350zspl
i have installed at least 1 dozen t1 systems
2 sealed the rest ported
i did not like the waY they sound sealed
Old Nov 2, 2007 | 10:42 AM
SuperBlack350z
really? I thought it sounded great sealed in a 1.00 cubic feet box. This was in a z as well.
What cars did you install it in?
Old Nov 2, 2007 | 10:58 AM
350zspl's Avatar
350zspl
all ported sounded great on rms or more than rms
the 2 that were sealed were trunk cars
1 each T1 10" off a punch 600.1
the other was sealed in a trunk millenia 1 each T 1 12" off t5001bd
just did not get low or loud in them trunk set ups sealed
sorry brother
Old Nov 2, 2007 | 03:40 PM
kullnan's Avatar
kullnan
thanks for all the info guys. ok the specs for the box are as follows:
Airspace: approx. 1.41 cu. ft. total. The box is divided into two chambers with .70 cu ft per sub/chamber.
Mounting Depth: 8.5"+
Mounting Hole: 9 1/8" this is standard for most 10" subwoofers
Condstucted with 3/4" MDF
Sealed Airtight
Terminals installed ready to wire
Covered in high grade Automotive Black Carpet.
i just picked up a cheap amp for the budget im going for a Alpine PDX-1.1000.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Kakipopo
Jan 24, 2004 07:49 AM
zand02max
Jul 21, 2003 06:21 AM
onecoolee
Mar 9, 2003 01:00 PM
