polyfil help please
Old Nov 6, 2007 | 01:45 PM
kullnan's Avatar
kullnan
Default polyfil help please
hi guys, just went to walmart and picked up some polyfil for the zenclosure box i just bought. but i was reading around the forums and found alot of people put polyfil in their boxes, but all in different ways. i read some people stapled it to the walls or glued it, and some just threw it in there. i just want to know if it matters or is there a best way in doing it. thanks.
Old Nov 6, 2007 | 01:51 PM
Zrealsoon's Avatar
Zrealsoon
Little dots of glue... oh and make sure you listen a lot to the sound before it... and then after.. I hit a few situations where the polyfil just made the sound worse (in this case less low bass).
Old Nov 6, 2007 | 02:16 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Staples work great - you don't want the polyfill rubbing against the back of the woofer cone or spider.
Old Nov 7, 2007 | 04:53 AM
kullnan's Avatar
kullnan
alright thanks for the input guys =)
Old Nov 7, 2007 | 05:06 AM
StreetOC192's Avatar
StreetOC192
You really need to know "WHY" you would add polyfill. Polyfill is added to slow down the wavelengths to make the sub 'think' it's in a larger enclosure.
Things to consider:
-What is the optimal recommended enclosure size for the sub
-What is the cu ft of the enclosure being used
I usually use staples but dots of glue would work. you just don't want it loose in there as stated by Paul350Z already.
PureR3d
Aug 20, 2015 04:34 PM
cashmoney03
Jan 5, 2015 12:08 PM
Justin311x
Jan 2, 2005 06:13 PM
