Where to mount jl 500/1?
Old Nov 7, 2007 | 10:57 AM
gti303's Avatar
gti303
Default Where to mount jl 500/1?
I'm gonna buy the wicked cas glovebox box, and a JL10W3V3, just thinking of possible places to mount the JL 500/1 that is the most hidden/stealth. Any suggestions?
Old Nov 7, 2007 | 10:59 AM
350zspl's Avatar
350zspl
glove box for amp behind passenger seat
wicked cas box in glove box behind driver seat
Old Nov 7, 2007 | 11:00 AM
Nexx's Avatar
Nexx
stock bose sub location.
Old Nov 7, 2007 | 11:11 AM
StreetOC192's Avatar
StreetOC192
+1
Unfortunately that's where the WickedCAS box goes.
Old Nov 7, 2007 | 02:05 PM
Get_Zwole's Avatar
Get_Zwole
just throw it in the stock glove box location i never use it for anything at all really hopefully you dont either.
Old Nov 7, 2007 | 03:34 PM
gti303's Avatar
gti303
won't it get too hot in there? Do I have to fabricate something so that air can flow underneath?
Old Nov 7, 2007 | 04:28 PM
Get_Zwole's Avatar
Get_Zwole
doubt it i have 2 amps one dls 2 channel and one jl 500/1 in my bose cubby it has the perforated door but my seat is usually on it all the time. Ive never had a problem i think it will be fine. A good amp is hard to overheat.
Old Nov 7, 2007 | 07:54 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
2006350zSA, clear out your PM. I'm ready to pay for the 680. let me know the paypal again.
Old Nov 8, 2007 | 03:51 AM
cbr900son's Avatar
cbr900son
If ur worried get a computer fan and hook up to the 12 volt on wire (takes barely any power at all). I've seen that done before for amps.
Old Nov 8, 2007 | 04:49 AM
350zspl's Avatar
350zspl
install 1st
if it gets hot it will go into thermo protect
then you will know if you need a fan
i have been using and installing car audio since 1986 and never had to instal a fan EVER
you'll be okay
cross the fan bridge if you get to it not before
Old Nov 9, 2007 | 10:44 AM
Integrity's Avatar
Integrity
I've been considering amp locations recently as well. The problem I have with the glove box location is the HD for my NAV system. The amps themselves won't over heat, but who knows what they'll do to the nav computer. I'm considering one under each seat.
Old Nov 9, 2007 | 11:08 AM
350zspl's Avatar
350zspl
i do not like mounting anything under seats
if windows are left open and rain comes ( screwed)
if someone spills a drink ( screwed)
plus hard to access for adjustments
my .02 cents
Old Nov 9, 2007 | 11:28 AM
Integrity's Avatar
Integrity
my .02 cents
Good point. Any suggestions? The space behind the sub (under strut box) is where my nitrous bottle is. The area in front of it is my only trunk space. Guess I'm screwed.
Old Nov 9, 2007 | 11:48 AM
350zspl's Avatar
350zspl
i would mount in
1- glove box behind passenger seat
2- glove box behind driver seat
3- buy amp rack from Mike at Zenclosures around $ 50
these are the 1st three that come to mind
are you feeling any of these
Old Nov 9, 2007 | 11:53 AM
Integrity's Avatar
Integrity
i would mount in
1. The hard drive for my nav is in there. I'm concerned the amps will overheat the navigation system.
2. I'd have to remove the stock bose speaker. I suppose I should do it anyway to get rid of the extra weight.
3. I'll check out his enclosures now.
Thanks for tips!
Old Nov 9, 2007 | 12:35 PM
350zspl's Avatar
350zspl
Thanks for tips!
going off line until monday
sorry
Old Nov 9, 2007 | 12:42 PM
lbz's Avatar
lbz
+1 on the locations behind the seats. Stealth, easy to get to, dry, etc. I have my RF amps there which actually have the heat sinks on the bottoms (dumb, I know) so to avoid heat issues, I used longer mounting screws and put little 1" blocks of wood (painted flat black) between the amp mounting points and the MDF mounting surface.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
