Looking for a sweet amp? A ZED for the Zed!
Old Nov 8, 2007 | 05:11 AM
StreetOC192's Avatar
StreetOC192
Default Looking for a sweet amp? A ZED for the Zed!
Just an FYI if you are in the market for an amplifier!
I am about to purchase a couple new amps and contacted Steve Mantz of ZED Audio. He advised that the current production units are almost sold out and he won't be producing any more until March 2008. I had told him that I was interested in the Minilith and The Deuce and he advised he only has 2 Miniliths left (1 after I place my order ) and about 20 The Deuces left, he did not divulge quantities of the Gladius or Draconia left, and the Megaliths are gone.
If you don't know who Steve Mantz is, you can Google his name and start reading. He wrote up a little autobiography and you can read it on his site HERE.
Old Nov 8, 2007 | 09:40 AM
350zspl's Avatar
350zspl
i already got a duece with brown burr upgrade
hollah
i am running it at 2 ohms
400 watts x 2
you got good taste
zed
mcintosh
zapco
straight SQ for mids and highs
use a 80 amp anl fuse not 60 @ 2 ohms
and i run zero awg to mine with sound quest reducers
Old Nov 8, 2007 | 09:56 AM
StreetOC192
That's what I'm getting, The Deuce with BB upgrade for my front stage. Getting a Minilith for my sub running 1 Ohm.
I would really like to change out my sub to a DD Z10, but it's wayyyy too deep for my understrut box......and I really don't have time nor energy to custom fab anything. But if I do, I would strap 2 Miniliths together for 1200 watts into 1 ohm (rated power of course)
Old Nov 8, 2007 | 10:18 AM
350zspl's Avatar
350zspl
i am real big on digital designs
i speak with Alan Dante from time to time
he is the world record holder over 180 DB
1 each 18" digital design
4 each stetsom 7k vulcan strapped
28,000 watts on 1 sub
trunk car
Volvo
i like the 9512G and 9515G
this is what Dante uses 18" 1 each with composite cone
http://www.ddaudio.com/dd/GalleryWoo...Z12redside.jpg
Old Nov 8, 2007 | 10:19 AM
350zspl's Avatar
350zspl
forget your trunk space
build your dream enclosure
**** it only live once
Old Nov 8, 2007 | 10:29 AM
350zspl's Avatar
350zspl
i am real tight with the owners of RD Audio
Revolution Design
below is my Sound Quality enclosure with my Daily RD Alpha V.2 15"
if you want to get an SQ sub
i can hook you
they do 12" the smallest in this series
i put 5000 watts to it at 30 hertz
kills the lows
you can build a box and do a 12"
Alpha Series V.2 Subwoofers
Alpha Series are a mix of SQ and SPL making them great for street bass or stock SPL events. They have great low bass capabilities it a small to mid sized ported box. With 1000 watts there loud, with 2000 they are on the next level. They can also be placed in small sealed enclosures for tight accurate bass while handling 2000 watts of clean power. Having almost 3” of excursion it makes the Alphas a jack of all trades. The second version of these subwoofers is a complete upgrade. They handle more power and handle the power excellent at low frequencies. They have even better Sound Quality. The newly redesigned Alpha series is an excellent all in one subwoofer.
Alpha Series V.2 new features:
New cone with more Kevlar fiber
Upgraded Spider and surround
Newly designed High temp Voice coil that is 10mm longer then the first version
New custom tooled Back plate and Front plate
Woofer Description
2000 Watt Subwoofers
Cast aluminum basket
Long fiber non pressed paper cone
Kevlar reinforced cone
Wide roll extra thick surround foam
Extended neck joints on cone, coil, and spider
Vented three inch high temp aluminum voice coil
Long excursion motor structure
Low carbon thick front and new deep rounded back plate
Powerful 1" dual stacked 120 oz magnets
Resign impregnated polycotton spider with integrated heavy duty tinsel leads our spiders will not sag even after years of play
Available in 12/15/18" * 18" is a custom build, 15" model pictured
New 550+ oz. motor structure
Specifications
Box suggestions:
Please contact us for custom designs *
Box suggestions port & driver already included
Alpha 15d2 3.25ft3 2(4" ports x 15.75" long) 36hz. 4.5ft3 2(4" ports x 9" long) 36hz.
Alpha 12d2 2.0ft3 2(3" ports x 12.5" long) 38hz. 3.0ft3 2(4" ports x 14.21" long) 38hz.
Alpha 12d4 2.5ft3 2(4" port x 12.5" long) 42hz. 2.5ft3 2(3" ports x 8.35" long) 38hz.
Alpha 12d4/2 1.0ft3 sealed 1.5ft3 sealed
Specifications coming soon
Home :: Products :: About :: Support :: Dealer Locator :: Gallery :: Contact
Copyright © Revolution Design Audio :: Design by Studio EFX
Old Nov 8, 2007 | 10:51 AM
StreetOC192
I'll let you know what my plans are. I really don't know if I want to go with a 12" in the Z or not. I want to see how this Diamond D610 does with 600rms versus the 380rms it's getting now (admittedly poor initial planning on my part).
Old Nov 8, 2007 | 11:15 AM
350zspl's Avatar
350zspl
i am no SPL pusher but it is my passion
i enjoy big scores in the lanes with SPL set ups
but i need SQL for daily
i am at your service
Old Nov 8, 2007 | 11:59 AM
StreetOC192
Thanks man, I appreciate it. I'll be sure to bounce my final plan off of you before committing.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
