Weak radio signal FM AM ?
Old Nov 12, 2007 | 10:33 AM
SeanMO's Avatar
SeanMO
Default Weak radio signal FM AM ?
After installing a new headunit has anyone wlse had a weaker than stock radio signal? I was just wondering if this was common or not. BTW the unit was a Avic - Z1
Old Nov 12, 2007 | 10:34 AM
deviljon's Avatar
deviljon
i had that problem with my avic D3. supposed to connect two blue wires or something. i think i connected the wrong ones because it's still weak.
Old Nov 12, 2007 | 11:38 AM
StreetOC192's Avatar
StreetOC192
You have to hook up the blue "power antenna" wire from the headunit to the adapter harness. Even though the Z does not have a power retracting antenna it DOES have a powered signal booster that gets it's 12v signal from the power antenna lead.
Old Nov 12, 2007 | 12:33 PM
350zspl's Avatar
350zspl
with pioneer double dins
you will get weak signal unless I THINK , I SAID I THINK
you'll need to conect the blue wire and the blue wire with white stripe
also there is a funtion to program relating to am fm reception to activate
thru touch screen
Old Nov 12, 2007 | 01:34 PM
cbr900son's Avatar
cbr900son
+1 when i installed my kenwood 7100 my blue wire came disconnected when i was moveing wires around and reception went to ****.
Old Nov 12, 2007 | 02:37 PM
deviljon's Avatar
deviljon
thru touch screen
i connected the 2 wires but still have weak signal.. messed around with some of the radio antenna settings in the menu but still didn't work.
is there another blue wire that i was supposed to connect to?
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Sailors350Z
Sep 25, 2015 08:21 AM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
