1-JL 10W6v2, 500-1000 watts enough bass
Old Nov 26, 2007 | 06:32 PM
Ken7258's Avatar
Ken7258
Default 1-JL 10W6v2, 500-1000 watts enough bass
Title says it all. I see quite a few 1-3 sub boxes. For excellent and powerful but not booming bass that drowns out all other sounds, is 1 10W6 in a ZEnclosures 1.35 cubic foot box with 500-1000 watts enough. I listen to all types of music but mostly rock/popular. Besides more bass, what would another 10w6 add . . . and would it just overpower the mids and tweeters?
Ken
Old Nov 26, 2007 | 06:56 PM
SuperBlack350z's Avatar
SuperBlack350z
yeah, one w6 in the z is enough.
Old Nov 26, 2007 | 08:42 PM
ckthepilot's Avatar
ckthepilot
i have a 10w7 and it sounds awesome!
Old Nov 27, 2007 | 05:56 AM
clarkemtp's Avatar
clarkemtp
Depends on what your definition of "enough" is? Enough to pop your windshield out on the hood? No. Enough to provide balanced, listenable audio spectrum reproduction? Yes.
Good Luck.
Old Nov 27, 2007 | 06:03 AM
StreetOC192's Avatar
StreetOC192
I thought the Zenclosures under strut box was only about .75 cu ft? Or is the one with the built in amp rack the 1.35 cu ft?
Old Nov 27, 2007 | 06:17 AM
350zspl's Avatar
350zspl
will be enough for you
not enough for me
Old Nov 27, 2007 | 09:05 AM
Ken7258's Avatar
Ken7258
Thanks for the replies. ZEnclosures has a new box with an amp rack that is 1.35 cu. ft. On JL's web site they recommend and .65 cu. ft. box. What would a box this big do to the performance? Help or hurt? I like the idea of the amp rack. Zen does have a box without the rack that is .75 cu. ft. Would this be a better fit. I'm sure the 1.35 cu. ft. box would be perfect for a dual sub setup.
I still haven't decided on one or two subs. I do know what strong powerful tight bass is. In my home theater I have a custom made 300+ pound sub powered by a Crown K2 and eq'd by a Behringer Feedback Destroyer. This sub is as powerful as 8 Paradigm Servo 15's corner loaded. It is fast and tight. When a bomb explodes, dinosaur walks etc. your hair, pants legs actually shake and the house shakes. It's awesome.
Music is different. You want to feel a kick drum, just not have a boomy loud bass note that drowns out all other sounds. I do listen to music loud and do love bass. Thanks.
Ken
Old Nov 27, 2007 | 09:51 AM
StreetOC192
Well if you want to utilize the amp rack for show, get that box. if the internal volume is too big for 1 sub (which it will be) just fill space inside the enclosure by gluing blocks of wood inside until you achieve the proper volume for the sub chosen.
Instead of a JL 10w6, you might be happier with a Image Dynamics IDMAX10V.3 (either dual 2 ohm or dual 4 ohm depending on the amp you pick out) which will handle 1000 rms watts. The depth on the IDMAX 10" is 7.6" which may not fit in the .75cu.ft. under strut box without some kind of spacer or extra baffle.
CrowzRSA
Sep 21, 2015 04:00 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
MustGoFastR
Jan 11, 2005 11:56 AM
eliminate
Dec 26, 2002 08:02 PM
Ricky
Nov 28, 2002 12:54 PM
