Adding steering wheen audio controls to a base model
Old Dec 11, 2007 | 07:56 AM
06blueZ's Avatar
06blueZ
Default Adding steering wheen audio controls to a base model
I have been searching to see if this is possible and have not seen anyone that has added this to a base model. I know that there is wiring at the back of the radio for what appears to be the audio controls, but has anybody added the steering wheel buttons to a base model?
I think that part number 25550-CF40A is what will be needed.
My local delaer is listing this as $58. not too unreasonable to add this I think. The only thing that I have to check is if there are any plugs/wiring in the steering wheel that may accept the steering wheel radio assembly.
Has anybody added this? can anybody confirm the part number?
Thanks!
Old Dec 11, 2007 | 08:11 AM
06blueZ's Avatar
06blueZ
Edit... 25550-CF40A is on order. Will update if it contains the cruize control and audio buttons.
Old Dec 11, 2007 | 08:32 AM
drumminguy81's Avatar
drumminguy81
i have done it.. though my car is not a base model, it was the track but had to steering wheel controls. i dont remember the part number but it was one number for both sides they come as a set so you will have to replace the cruise as well.. there is no pre existing wiring for them in the car so you will have to add pins to the steering wheel side for the controls to attach to. im not sure that it can be done with the factory radio i have an after market deck so i used a peripheral interface to hook it up.. all in all it was fairly easy if you are electronically inclined.. i know there is a how to on it somewhere on this site because that is what i used to do mine.. ill look and see if i can find a link for you.. good luck
Old Dec 11, 2007 | 08:34 AM
drumminguy81
i dont have a link but if you search thread titles for "steering wheel controls" it is the very last thread on the first page titled DIY steering wheel romoval and controls installation.. or something of that nature..
Old Dec 11, 2007 | 09:17 AM
06blueZ's Avatar
06blueZ
Thumbs up
thanks alot for the suggestion. I found the thread
https://my350z.com/forum/showthread....wheel+controls
post #90 confirms that this part is what I need for my 06, it seems to just plug in. (audio controls at least, not the cruise...)
Im going to order this and will confirm if it works for me.
Thanks!
Old Dec 11, 2007 | 09:41 AM
drumminguy81
it would make sense for yours to have the wiring pre existing, mine didnt because its an 03 and steering wheel controls were not available as an option until 06.. you may get lucky..
Old Dec 11, 2007 | 09:45 AM
06blueZ's Avatar
06blueZ
Parts on order... i will update this weekend when i get a chance to install it! keeping my fingers crossed...
Old Dec 11, 2007 | 03:38 PM
tight350z's Avatar
tight350z
sweet.. ill keep an eye on this thread.. id love to have steering wheel controls with my aftermarket radio!
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
